team, please help me understand state_type value. when I executing API to check on host status I'm looking for last_hard_state and if its = 1, fire alert excluding 2 which mean host unreachable. But state_type is always = 1 regardless as far as I can see.
Please advise.
last_hard_state vs state_type
Re: last_hard_state vs state_type
This is what "state_type" means:
in the REST API?
Are you saying that your host is in a SOFT state, but you see:state_type = 0 is SOFT
state_type = 1 is HARD
state_type = 1Be sure to check out our Knowledgebase for helpful articles and solutions!
nagwindmon
what state_type value suppose to be when a new host being added and it is up running to start with?
yes, running REST API
It should be:
provided the newly added host is in a HARD state.
nagwindmon
ok, got it. its still a bit confusing since it starts with 1 (hard state) then once issue has been detected it changes to 0 (soft) after x number of retires it goes back to 1 (hard) and stays so till another host state change occurs.
This is by design. Let us know if you have any further questions or it's ok to close this topic. Thanks!
nagwindmon
I'm good, thank you, go ahead lock it.
Good to get that cleared up. Locking thread.
