World map size and circulate
centricrm
Post by centricrm »
Hi, it is possible to start a World Map with my own default coordinates. Is it also possible to start the Word Map using the outlines of country? And is it possible to circulate the World Map so another country is shown after some time?
benjaminsmith
Re: World map size and circulate
Post by benjaminsmith »
Hi @centricrm,
The Views menu is used to circulate select pages/content from within Nagios XI. You can manage which pages to circulate and the speed from left side menu from the main Views page. To add a page to your View, simply click the hamburger menu in the upper right and select Add to My Views.
From the World Map, click on the gear icon in the upper left to set the coordinates for the center of the map (reload for changes to take effect)
You can add the main World Maps page to your Views, but to circulate through various maps, I would recommend using NagVis and create custom maps.
Useful Documentation
Understanding and Using Views
How to Integrate NagVis with Nagios XI
Let me know if you have further questions.
