MySQL Threads-connected Issue
mindspring
Post by mindspring »
Hi there,
I seem to have a problem with this monitor where it says critical even though I set --warning and --critical to higher than the actual number
Please see attached.
My command in core config manager looks like this:
--hostname=sql-new.servers.chat2brand.com --port=3306 --username=nagios --password="xxxx" --database=information_schema --mode threads-connected --warning 450--critical 600
Re: MySQL Threads-connected Issue
You are missing a space after the 450
--hostname=sql-new.servers.chat2brand.com --port=3306 --username=nagios --password="xxxx" --database=information_schema --mode threads-connected --warning 450--critical 600l
should be
--hostname=sql-new.servers.chat2brand.com --port=3306 --username=nagios --password="xxxx" --database=information_schema --mode threads-connected --warning 450 --critical 600l
