Recently upgraded to XI 5.6.5, when viewing a graph and then using the hamburger options menu to download (PDF,JPEG,etc) the following error is returned.
Couldn't create temporary file. Check that the directory permissions for the /temp directory are set to 777.
Submitting this, just in case permissions on the dir were changed by the XI version upgrade.
Please advise,
Download options in graph explorer have a permission issue
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
benjaminsmith
Re: Download options in graph explorer have a permission iss
Hi @TBT,
I've been able to re-create this on my test system and I'll get a bug report filed. Thanks for letting us know, and in the meantime you can change the permissions on that directory by running the following command.
chmod 777 /usr/local/nagiosxi/html/includes/components/highcharts/exporting-server/temp
