Need Host IP in status.dat file
anjali
Post by anjali »
Hello Team,
I am reading data from status.dat file by converting it to JSON file and render that data in separate UI. Now I need Host IP but I am not getting that in status.dat file, so can you help me in that?
Re: Need Host IP in status.dat file
This isn't in the status.dat
I would recommend using the JSON query API
/nagios/jsonquery.html
select OBJECT JSON API
select hostlist
select True for "Show Details"
This will give you a URL like this
http://YOUR_NAGIOS_HOST/nagios/cgi-bin/objectjson.cgi?query=hostlist&details=true
Then the address field for each host has what you are looking for
anjali
Post by anjali »
Thanks, it works.
But I need to call that URL from my PHP script. When I am calling it gives an unauthorized error. So pls help me in that
anjali wrote:Thanks, it works.
You would need to add your credentials to the call in your PHP script.
On some systems you may be able to do this by changing the URL to
http://USERNAME:PASSWORD@YOUR_NAGIOS_HOST/nagios/cgi-bin/objectjson.cgi?query=hostlist&details=true
anjali
Post by anjali »
Thanks, it works.
Great!
Locking thread
