Wizard template Notification Interval not retained
DFaught
Post by DFaught »
I have a Wizard template defined with the Notification Interval set to 0 (zero) so that only one notification will occur for an alert. When I go back to edit this template, the Notification Interval is always set back to the default 60 instead of picking up the already defined zero value. This seems like a bug to me, and should be pretty easy to recreate.
I have not noticed this behavior for any other values in the template.
Thank you for your kind attention.
Re: Wizard template Notification Interval not retained
Looks like you found a bug.
You can unzip and uploaded the fixed attached php file to /usr/local/nagiosxi/html/config/managetpls.php to resolve the issue.
this will be included in future releases.
managetpls.zip
