Unable to print graphs
vijilants
Post by vijilants »
System:
System
Nagios XI version: 5.6.5
XI installed from: manual
XI UUID: 04ca27fb-9572-4aa4-969b-f5cf74fa0c2c
Release info: londnms1 3.10.0-862.11.6.el7.x86_64 x86_64
CentOS Linux release 7.5.1804 (Core)
Gnome is not installed
System running ramdisk
Can you please help.
I am trying to print graphs but every time I use the right hand icon and use the download button (download as pdf) I get the following message...
Couldn't create temporary file. Check that the directory permissions for the /temp directory are set to 777.
I have checked both systems and neither have a /temp directory.
This has not happened before.
Can you please advise as this is rather urgent.
Re: Unable to print graphs
The directory in question is
ls -dl /usr/local/nagiosxi/html/includes/components/highcharts/exporting-server/temp/
vijilants
Post by vijilants »
Thank you , so is that a chmod 777 on that directory ?
Many thanks
vijilants wrote:Thank you , so is that a chmod 777 on that directory ?
Many thanks
Yes, that is correct there.
vijilants
Post by vijilants »
Great,
All good now and thanks !
Not sure as to why it happened on both our stsems but both are good now.
vijilants wrote:Great,
Great!
Locking
