URL Monitoring
mananatmacys
URL Monitoring
I currently have multiple URL's being monitored, however, I am not able to see them or find them anywhere on the instance. Where can I find the URL's? They're not shown in hosts.
Re: URL Monitoring
They should show up under hosts, and under services. First thing to check and double check is whether or not a configuration change is pending. Go to Configure -> Core Configuration Manager, and see if Apply Configuration on the left menu is red. If it is, apply the configuration, and then see if your sites show up.
mananatmacys
Re: URL Monitoring
mbellerue wrote:They should show up under hosts, and under services. First thing to check and double check is whether or not a configuration change is pending. Go to Configure -> Core Configuration Manager, and see if Apply Configuration on the left menu is red. If it is, apply the configuration, and then see if your sites show up.
Everything is configured. It is still not showing up under either of them. I do know for sure that it is being monitored.
Re: URL Monitoring
Could you PM me your system profile and a URL that you are trying to monitor? I will take a look at it and see if I can see some reason why they wouldn't show up.
