We are currently using smtp.office365.com for sending mails from Nagios XI. As Microsoft is soon removing support for older versions of TLS we have received a notification that the mails sent from Nagios are transported over a connection secured by TLS 1.0.
Is this correct?
If so, how do we remedy this?
I have done some digging myself, based on a hunch that this could be linked to the old version of PHP shipped with CentOS.
I found that PHPMailer uses stream_socket_enable_crypto (docs) for securing the connection, but as we are using PHP 5.4 the most secure flag available is STREAM_CRYPTO_METHOD_TLS_CLIENT. This appears to lead to a call to TLSv1_client_method() (PHP 5.4.16 source), which I believe is for negotiating a TLS 1.0 connection.
If this is correct (and I may very well have taken a wrong turn) the most obvious solution would be moving to a newer PHP release.
Is upgrading the installed version of PHP officially supported, or are we better off looking to sendmail for future delivery of mail?
Nagios XI version: 5.6.5
XI installed from: source
CentOS Linux release 7.6.1810 (Core)
PHP Version: 5.4.16
On further inspection, changing the flag in /usr/local/nagiosxi/html/includes/phpmailer/class.smtp.php from STREAM_CRYPTO_METHOD_TLS_CLIENT to STREAM_CRYPTO_METHOD_SSLv23_CLIENT may lead to calling SSLv23_client_method(), which is the "version-flexible" according to the manpages. I will report back when I can see whether this fixes our problem.
