Syntax to submit nsclient++ check_drivesize with nrpe
awilson
Post by awilson »
Hi. We have been using the check_nt protocol to submit nsclient++ checks. I'm trying to use nrpe instead, but I'm not having success getting nrpe to use the parameters. The check_nrpe command is configured as follows:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
I tried:
-a '-p ##### check_drivesize "warn=free<20% crit=free<10%" drive=*'
in $ARG1$ leaving $ARG2$ blank and I get:
Incorrect command line arguments supplied
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.15
//snip
Is there an obvious error?
Thanks.
Re: Syntax to submit nsclient++ check_drivesize with nrpe
The example command that you have shown is not formatted correctly and that is generating the errors.
What you would need to do is just put in the command in the $ARG1$ field and in the $ARG2$ field, you would put in the arguments required for the command.
For the drive check, you would put this in the $ARG1$ field.
check_drivesize
And in the $ARG2$ field, you would put in all of the following to test the drive C free space.
-a drive=C: 'warning=free<20%' 'critical=free<10%' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${free_pct}% free / ${size} total}' top-syntax='${status}: ${problem_list}'
This will generate an alert on the following.
Warning: 10% Free
Critical: 5% Free
This example came from the following KB article.
https://support.nagios.com/kb/article/d ... s-770.html
Take a look at it for more details.
awilson
Post by awilson »
Thank you so much! That worked. //smile
awilson
Post by awilson »
You can close this.
awilson wrote:You can close this.
Great!
Locking
