Is there any maintenance that can be ran on the storage location where my Log Server snapshots are stored?
This might have more to do with my storage than with Log Server, but I've noticed in the last couple weeks that when I delete an old snapshot that it won't free up any space in the repository where they are stored. It's really weird because I know the snapshot is like 300-400GB+ in size, but the amount of free space will remain the same after it's deleted.
It happened this morning after I deleted yesterdays snapshot. Not sure what that's about.
It looks like the metadata-curator and snapshot-curator files are up to date.
Thank you.
Snapshot storage maintenance
Re: Snapshot storage maintenance
Not really.rferebee wrote:Is there any maintenance that can be ran on the storage location where my Log Server snapshots are stored?
It is worth pointing out that each snapshot only contains the difference from the previous snapshotted indices and any new indexes.
So, each snapshot isn't the whole of all of the indices, and deleting one snapshot may not make much difference if any, it would only remove the amount of data that is in any index that are not also contained in any other snapshots.
I understand that, I guess why I'm confused is because on average we get around 250GB+ worth of logs everyday. I would think that deleting the snapshot would remove at least that much data.
For example, before the snapshot was taken last night we had 1345.92GB of free space and after it finished we had 1069.40GB of free space. So, deleting the snapshot from the prior day should free up the space taken by the index the day before it was taken since that data is now contained in today's snapshot, right?
No. Because today's snapshot is told that it needs a copy of all of the indices that were active at the time the snapshot was created.rferebee wrote:So, deleting the snapshot from the prior day should free up the space taken by the index the day before it was taken since that data is now contained in today's snapshot, right?
Now when you delete yesterdays snapshot the system knows that it was the only other snapshot that contained yesterdays index, and as such it transfers that data to today snapshot because you will still need it if you restore todays snapshot.
Now, if you removed the OLDEST snapshot on the system, it most certainly should contain indices that no other snapshots contain and as such they would be completely removed from the drive, and it would free up the space they were taking, and they would be gone forever.
Ok, I understand.
Thank you for clarifying. You can lock this.
Great!rferebee wrote:Ok, I understand.
Locking
