check_http & ssl
crechet51
check_http & ssl
Post by crechet51 »
I have a site httpS, which I need to check with check_http and find a line in it that contains a specific word.
I do:
 check_http! -S -s "123"!
As I understand it: S - use https instead of http
I get:
HTTP CRITICAL: HTTP/1.1 301 Moved Permanently - string '123' not found on 'https://site.com:443/'
Re: check_http & ssl
it looks like the site you are pointing check_http to has a redirect, it would be easiest to set check_http to follow the redirect with the -f follow flag
check_http! -S -s "123" -f follow!
crechet51
Post by crechet51 »
I set
check_http!-f -s "123"!
and I get:
check_http: Invalid onredirect option - -s
:roll:
You missed the word follow
check_http!-f follow -s "123"!
crechet51
Post by crechet51 »
Great! It's works. Thank you.
crechet51 wrote:Great! It's works. Thank you.
Great!
Locking
