Routers and Switches templates
elade
Post by elade »
I’m writing automation for deploy Nagios alerts and I’m having trouble using Network Switch / Router wizard.
I found out how to create the files in /etc/mrtg/conf.d/ and /usr/local/nagiosxi/tmp/ (/usr/bin/cfgmaker).
After that how I create the X.X.X.X.cfg file and import it to XI?
There any way to use this wizard in ansible play-book?
mbellerue
Re: Routers and Switches templates
Post by mbellerue »
The best way to create the configuration file via automation would be to use the Nagios XI API. You can get the API key for authentication by clicking on your username in the upper right corner of Nagios XI. You can get a lot of good information on how to use the API from Help -> Config Reference.
curl -XGET "http://<NagiosXIHostOrIPAddress>/nagiosxi/api/v1/config/host?apikey=<YourAPIKey>&pretty=1"
elade
Post by elade »
Hi mbellerue,
Thank you.
You can close the topic
elade wrote:Hi mbellerue,
Thank you.
Great!
Locking
