Performance Graphe => again
scharft
Post by scharft »
After every reboot of the instance, the performance grapher does not start.
We have to manually start him otherwise we have no grapical data.
How can we fix that?
best regards
Re: Performance Graphe => again
The commands depends on the OS but the following will likely set npcd to start on boot
chkconfig npcd on
