root@nagios1:[~]: /usr/local/nagios/libexec/check_ncpa.py -H <server> -t 'token' -P 5693 -M '/windowscounters/PhysicalDisk(0 C:)/Avg. Disk Queue Length sleep=1'
The specified counter could not be found.
root@nagios1:[~]: /usr/local/nagios/libexec/check_ncpa.py -H <server> -t 'token' -P 5693 -M '/windowscounters/PhysicalDisk(0 C:)/Avg. Disk Queue Length?sleep=1'
I was able to get the command above to run. It looks like there was a change to NCPA sometime after 2.1.2 that requires -q sleep=1. I could not get the command to work with PhysicalDisk(0 C:). Never mind this, I had a typo in my command. It does work with PhysicalDisk(0 C:)
Do you have an example of a command where %20 was working, and now it isn't? Also what version of NCPA did you upgrade from? I'll see if I can replicate the setup on my side.
