Uptime Powered
martinsrs
Uptime Powered
Post by martinsrs »
Good afternoon
I am trying to configure nagios to alarm if the server is powered on for more than 60 days.
But I can't, does anyone know how I can do this?
With -c it alarms when it is shorter than the time I set.
Re: Uptime Powered
The default unit is minutes
-u, Time unit of measurement (seconds|minutes|hours|days) (default: minutes)
Try
/usr/local/nagios/libexec/check_uptime -c 60 -u days
or convert to minutes 60 * 24 * 60 = 86400
/usr/local/nagios/libexec/check_uptime -c 86400
martinsrs
Re: Uptime Powered
Post by martinsrs »
scottwilkerson wrote:The default unit is minutes
Try
I want it to be critical when it is on for more than 60 days, this command is for when it is less than 60 days on.
Re: Uptime Powered
martinsrs wrote:I want it to be critical when it is on for more than 60 days, this command is for when it is less than 60 days on.
Not true, here's my example with a machine that has been up 85 days (more than 60)
[root@localhost ~]# uptime
 11:44:37 up 85 days,  2:25,  2 users,  load average: 0.35, 0.36, 0.25
[root@localhost ~]# /usr/local/nagios/libexec/check_uptime -c 60 -u days
Uptime CRITICAL: 85 day(s) 2 hour(s) 25 minute(s) | uptime=85.000000;;60.000000;
for clarity, the command for LESS THAN 60 days would be
/usr/local/nagios/libexec/check_uptime -c 60: -u days
martinsrs
Re: Uptime Powered
Post by martinsrs »
How do I do this in Windows, is it the same thing?
In NSClient it looks like this:
alias_up = checkUpTime MinWarn = 1d MinWarn = 1h
And in Webadmin I passed the command that spoke.
martinsrs
Re: Uptime Powered
Post by martinsrs »
Re: Uptime Powered
martinsrs wrote:How do I do this in Windows, is it the same thing?
No it is definitely different.
something like
alias_up_60 = check_uptime "crit=uptime > -60d"
https://docs.nsclient.org/reference/win ... eck_uptime
