getting "Backend Login to the Core Config Manager failed" error when trying to add a new host for monitoring. running latest v5.6.6
when i run /usr/local/nagiosxi/scripts/reconfigure_nagios.sh, get the following error when importing ccm
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
- Importing: /usr/local/nagios/etc/import/CLT-PBX.cfg .. ERROR
Field 'display_name' doesn't have a default valueEntry config_name::-CLT-PBX inside tbl_service could not be inserted: 1<br>
- Importing: /usr/local/nagios/etc/import/pPRIJvjW.tmp.cfg .. ERROR
Field 'alias' doesn't have a default valueEntry config_name::CLT-PBX inside tbl_service could not be inserted: 1<br>Entry host_name::CLT-PBX inside tbl_host could not be inserted: 1<br>
Error - Backend login to the core config manager failed
benjaminsmith
Re: Error - Backend login to the core config manager failed
Hi @olabsid,
I'll go head a close this out as the issue has been posted to the customer forum. Please open one post per topic so we can best focus our efforts. Thanks.
