Hi All,
We have new requirement to monitor a running log file of a unix server using Nagios core. I have checked for all ways to get a plugin to do this but unfortunately i couldn't find the plugin.
Original requirement:
Server: dc2drpas008
Logfilename: testfile.log
Logfilepath: /root/linux-nrpe-agent/testfile.log
Error message: error and warn
Please help me in finding the script to monitor a running log files.
Thanks and Regards,
Srinija.
Monitor a running log file of Unix server using Nagios core
Srinija544
Re: Monitor a running log file of Unix server using Nagios c
One of the most common Log plugins is check_logfiles
https://exchange.nagios.org/directory/P ... es/details
Srinija544
Hi scottwilkerson,
Thank you for your response.
I have tried to configure the check_logfiles which was provided in the below URL and made some changes. Please find my script:
cat /usr/local/nagios/libexec/check_logfiles.cfg
$scriptpath = '/usr/local/nagios/libexec';
$MACROS = {
MY_ERROR_MACRO => 'ERROR',
MY_VOLUME => '10'
@searches = (
tag => 'ERROR',
logfile => '/root/srinija.cfg',
criticalpatterns => 'ERROR',
script => 'check_logfiles.sh',
scriptparams => '$MY_VOLUME$'
options => 'noprotocol,script,perfdata'
AND
cat /usr/local/nagios/etc/check_logfiles.sh
#! /bin/sh
if [ -n "$1" ]; then
VOLUME=$1
fi
printf "It is %d:%d and my status is %s\n" \
$CHECK_LOGFILES_DATE_HH \
$CHECK_LOGFILES_DATE_MI \
$CHECK_LOGFILES_SERVICESTATE
printf "I found something funny: %s\n" "$CHECK_LOGFILES_SERVICEOUTPUT"
if [ "$VOLUME" == "X10" ]; then
echo "$CHECK_LOGFILES_MY_ERROR_MACRO" | tr 'a-z' 'A-Z'
else
fi
printf "Thank you, %s.Found the ERROR.\n" "$CHECK_LOGFILES_USERNAME"
Command in nrpe.cfg:
command[check_logfiles]=/usr/local/nagios/libexec/check_logfiles --config logdefs.cfg
Service:
use generic-service,srv-pnp
host_name hostname
# contact_groups cg_infra_unix_t2
# servicegroups sg_infra_unix
service_description Log file
check_command check_nrpe!check_logfiles
Error message after configuring the above scripts and command in Nagios:
NRPE: Unable to read output
Please help me in knowing whether the scripts and command which i wrote is appropriate or not.
Thanks and regards,
Srinija.
$MACROS = {
MY_VOLUME => '10'
@searches = (
tag => 'ERROR',
AND
#! /bin/sh
VOLUME=$1
fi
else
fi
Service:
host_name hostname
Thanks and regards,
Srinija.
I'm not an expert on this plugin but one thing that stands out is this
You need to make sure that the user NRPE is running as has access to this file.
Also, the file name you are showing don't match with the commands, for example, you have this
but you seem to be calling --config logdefs.cfg
and you showed this
but your NRPE command doesn't have the .sh on it
So I am a bit confused at how this is all working together.
Which begs the question, is it working? If not, what are you getting?
logfile => '/root/srinija.cfg',Also, the file name you are showing don't match with the commands, for example, you have this
cat /usr/local/nagios/libexec/check_logfiles.cfgCode: Select all
command[check_logfiles]=/usr/local/nagios/libexec/check_logfiles --config logdefs.cfgCode: Select all
cat /usr/local/nagios/etc/check_logfiles.shCode: Select all
command[check_logfiles]=/usr/local/nagios/libexec/check_logfiles --config logdefs.cfgWhich begs the question, is it working? If not, what are you getting?
Srinija544
Hi scottwilkerson,
Even I am confused how this plugin works.
Please find my changes on client server:
Nagios is owner for this file:
-rw-r--r-- 1 nagios nagios 14 Aug 29 16:44 srinija.cfg
command[check_logfiles]=/usr/local/nagios/libexec/check_logfiles.cfg --config check_logfiles.sh
Error message after configuring in Nagios:
please let me know if any changes needs be done.
Regards,
Srinija.
Regards,
Srinija.
this certainly isn't right, it looks like you are trying to execute a .cfg file (check_logfiles.cfg) and pass a shell script as a config (--config check_logfiles.sh)?Srinija544 wrote:Command in nrpe.cfg:
Before trying to add it to the nrpe.cfg, you need to make sure you can get the expected results running it from the command line on the system you are running it on.
Only once you know the proper syntax for the command should you move on to create the entry in the nrpe.cfg
