Im new to monitoring with nagios , so far i was able to install and monitor the host of the nagios , another server and a windows server with nrpe.
Problem is , the method i know is to create a custom cfg for each server , is it possible to have 1 cfg file to custom monitor all the servers?
I do not mean host group or service group , i what i mean is for example - servers.cfg
which will contain
host_name test-server
alias test-server
display_name test-server
address 10.0.0.1
check_commands check_ping,check_mem,check_load,check_ssh,check_disk,check_http
contacts [email protected]
contact_groups [email protected]
notification_interval 4
is this configuration possible? could you provide me with a method on how to make monitoring with nagios easier?
Custom template monitoring
Re: Custom template monitoring
This is not possible.
But once you define your hosts you can add multiple hosts to service definitions (either via hostgroups you comma separated in the host_name directive) and place them all in a single file
such as
such as
host_name test-server1,test-server2,test-server3
service_description Ping
check_command check_ping
register 1
service_description Memory
check_command check_mem
register 1
service_description Load
check_command check_load
register 1
service_description DISK
check_command check_disk
register 1
