Nagios XI intermittently fails on 'force an immediate check'
azreenariff
Post by azreenariff »
Dear Nagios Support,
We are using NagiosXI 5.4.13, running on RHEL 7.4 with 16 CPU, 32GB memory. Currently, we are experiencing some problem with the 'force an immediate check' where it fails, and during this time 'apply config' also not completing. However, the issue happens intermittently but for some long period of time, then it starts to be successful again and so on.
Urgently require your support to solve this problem. We have looked up and done recommendations and possibilities, but issue still persists. Need your kind assistance on which angle to move on to solve this problem.
Thanks.
Re: Nagios XI intermittently fails on 'force an immediate ch
When this is not functioning I would like to see what happens in this log when you attempt to Apply Configuration
Run the following from the CLI
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Apply configuration in the GUI
Wait a minute or so and send the output back to us.
Additionally send the output of the following command at the same time
tail -50 /var/log/cron
azreenariff
Dear Scott,
Kindly find attached the outputs as requested:
Thanks.
azreenariff
Hi Scott,
Please ignore my previous post. The logs were when it was successful. Will wait when it is not functioning and capture it again.
Thanks.
azreenariff
Hi Scott,
Kindly refer attached is during not functioning.
Thanks.
I think we are going to need a full system profile, I would suggest opening a ticket here
https://support.nagios.com/tickets/
Then send in a profile from Admin -> System Config -> System Profile
azreenariff
Hi Scott,
Ok. I have created the ticket.
Thanks.
azreenariff wrote:Hi Scott,
Thanks.
Locking, moving to ticket
