dear Expert
when we select Custom option for period, its displaying From and To option to select the period, however when we select
Last Week
This Month
Last Year
This Year
the From To option disappeared, however it should be display with period, just an example , if we select "Last Week", the period should appear as below
From 21-Aug-2019 11:00 To 28-Aug-2019 11:00
and same way if we select This Month
From 01-Aug-2019 00:00 To 28-Aug-2019 11:00
Regards
Last/This week/month/year, period should appear
Re: Last/This week/month/year, period should appear
This is done on purpose, for a very important reason, if you select a "Last/This week/month/year" report, it changes over time when placing elements on a dashboard or saving a report they will change to correspond to the current "Last/This week/month/year"zaji_nms wrote:the From To option disappeared, however it should be display with period, just an example , if we select "Last Week", the period should appear as below
When you choose the Custom option, the dates are locked and will not change, so saving the report is always those exact dates.
dear scottwilkerson
let date be in locked condition if selected Last/This Week/Month/Year but should show (light grey disable mode) the application taking which period upon selecting the drop down options.
because not showing the From To dates, we not using drop down option, maximum time we using Custom and providing the dates/period manually From To, so if Last/This Week/Month/Year will show the date , will learn over the period how the application calculating the period upon selecting options and will clear our doubt.
I have put my views clearly, its not a major case, may be later on you will think, you can close the case.
regards
regards
Your feedback is appreciated! I am going to close the case but wanted to make one last point on this statement
The date fields are not even shown when you select one of these, so there are no fields to place in a disabled mode, the date fields only displays on reports when you select "Custom" from the dropdown.zaji_nms wrote:let date be in locked condition if selected Last/This Week/Month/Year but should show (light grey disable mode) the application taking which period upon selecting the drop down options.
