Red Database Maintenance button in Admin Tab
cjsGSB
Post by cjsGSB »
We have successfully offloaded Mysql to a remote server according to the documents provided by NAGIOS.
Only issue we are seeing is the Data Maintenance Status button shows RED.
Is there a way to get this to change to GREEN ?
cjsGSB
Re: Red Database Maintenance button in Admin Tab
Post by cjsGSB »
took a look in /etc/cron.d/nagiosxi and see that dbmaint.php should run every 5 minutes.
Noticed there where no dbmaint.log in /usr/local/nagiosxi/var.
Running php -q /usr/local/nagiosxi/cron/dbmaint.php from command line runs successfully and the red button went away
running the same command and outputting logs to /usr/local/nagiosxi/var/dbmaint.log worked succesfully.
After i did this on the command line i changed ownership to nagios:users and permissions to 644.
With that i now see the logs is updated automatically every 5 minutes
Any reason Nagios didnt do this automatically?
cdienger
Post by cdienger »
What OS and XI version?
Anything logged in /var/log/cron or /var/log/secure when the cron tried to run before the log was put in place?
Does the nagios user ahve write permissions on the /usr/local/nagiosxi/ directory ?
cjsGSB
Post by cjsGSB »
we are running nagios xi 5.5.9 with RHEL 6.9
The logs show the same entries for the day before and after we created the logs
the permissions of the /usr/local/nagiosxi directory are 755 with owner root and group nagios
ssax
Dreams In Code
Post by ssax »
Run these:
chmod 0644 /usr/local/nagiosxi/var/dbmaint.log
chown nagios.nagios /usr/local/nagiosxi/var/dbmaint.log
Please post (or PM) the FULL output of these commands (as root):
chage -l nagios
chage -l apache
grep "User \|Group " /etc/httpd/conf/httpd.conf
tail -n100 /var/log/cron
cat /etc/cron.d/nagiosxi
grep nag /etc/group
ls -lh /usr/local/nagiosxi/var
cat /etc/sudoers*
su - nagios
/usr/bin/php /usr/local/nagiosxi/cron/dbmaint.php # NOTICE NO -q
Thank you!
cjsGSB
Post by cjsGSB »
chage -l nagios
Last password change : Aug 27, 2019
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
chage -l apache
Minimum number of days between password change : -1
Maximum number of days between password change : -1
Number of days of warning before password expires : -1
grep "User \|Group " /etc/httpd/conf/httpd.conf/httpd
# . On SCO (ODT 3) use "User nouser" and "Group nogroup".
# when the value of (unsigned)Group is above 60000;
# don't use Group #-1 on these systems!
User apache
Group apache
Sep 4 10:27:01 nagiosxi CROND[31912]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:27:01 nagiosxi CROND[31913]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:27:01 nagiosxi CROND[31917]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:27:01 nagiosxi CROND[31918]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:27:01 nagiosxi CROND[31919]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32347]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32349]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32351]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32350]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32348]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32353]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32352]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32358]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32359]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:28:01 nagiosxi CROND[32357]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[329]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[331]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[332]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[333]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[330]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[338]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[340]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[341]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[339]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:29:01 nagiosxi CROND[342]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[814]: (root) CMD (/usr/lib64/sa/sa1 1 1)
Sep 4 10:30:01 nagiosxi CROND[816]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[815]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok)
Sep 4 10:30:01 nagiosxi CROND[818]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[821]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[824]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[823]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[825]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[831]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[822]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[829]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[817]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:30:01 nagiosxi CROND[830]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1287]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1288]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1289]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1293]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1297]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1295]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1294]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1290]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1299]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:31:01 nagiosxi CROND[1298]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1729]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1728]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1730]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1731]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1736]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1737]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1739]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1742]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1740]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:32:01 nagiosxi CROND[1741]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2189]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2191]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2197]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2194]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2198]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2200]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2199]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2193]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2208]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:33:01 nagiosxi CROND[2195]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2666]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2668]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2669]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2673]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2676]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2672]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2675]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2674]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2678]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:34:01 nagiosxi CROND[2680]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3147]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok)
Sep 4 10:35:01 nagiosxi CROND[3148]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3149]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3151]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3152]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3154]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3157]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3155]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3160]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3161]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3156]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:35:01 nagiosxi CROND[3163]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3581]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3583]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3585]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3582]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3586]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3584]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3592]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3589]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3595]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Sep 4 10:36:01 nagiosxi CROND[3591]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
# /etc/cron.d/nagiosxi: crontab fragment for nagiosxi
# Backup MySQL & PostgreSQL Databases
0 7 * * * root /root/scripts/automysqlbackup
0 7 * * * root /root/scripts/autopostgresqlbackup > /dev/null 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1
01 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/recurring_downtime.php >> /usr/local/nagiosxi/var/recurringdowntime.log 2>&1
* * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1
grep nag /etc/group
nagcmd:x:501:apache,nagios
nagios:x:502:apache,nagios
total 17M
drwxr-xr-x. 2 root nagios 4.0K Aug 27 13:47 certs
-rw-r--r--. 1 nagios users 3.7M Sep 4 10:37 cleaner.log
-rw-r--r--. 1 nagios users 1.3M Sep 4 10:37 cmdsubsys.log
drwsrwsr-x. 2 apache nagios 4.0K Aug 27 16:08 components
-rw-r--r--. 1 nagios users 6 Sep 4 10:37 corelog.data
-rw-r--r--. 1 nagios users 0 Sep 4 10:37 corelog.diff
-rw-r--r-- 1 nagios nagios 1.5M Sep 4 10:35 dbmaint.log
-rw-r--r-- 1 nagios users 263K Sep 3 03:07 dbmaint.log-20190903.gz
-rw-r--r--. 1 nagios users 813K Sep 4 10:37 deadpool.log
-rw-r--r--. 1 nagios users 0 Sep 4 10:35 event_handler.lock
-rw-r--r-- 1 nagios users 1.9M Sep 4 10:37 event_handler.log
-rw-r--r-- 1 nagios users 227K Aug 31 03:08 event_handler.log-20190831.gz
-rw-r--r-- 1 nagios users 2.3M Sep 4 10:37 eventman.log
-rw-r--r-- 1 nagios users 196K Aug 31 03:08 eventman.log-20190831.gz
-rw-r--r--. 1 nagios users 278K Sep 4 10:37 feedproc.log
drwxrwxr-x. 2 nagios nagios 4.0K Aug 27 13:46 keys
-rw-r--r--. 1 nagios users 6.6K Sep 3 13:54 nom.log
-rw-rw-rw-. 1 nagios nagios 0 Aug 27 13:46 NXTI_Write_Test
-rw-r--r--. 1 nagios users 870K Sep 4 10:37 perfdataproc.log
-rw-r--r--. 1 nagios users 1.1K Aug 28 11:34 reportengine.log
drwxr-xr-x. 2 nagios nagios 4.0K Aug 28 14:19 subsys
-rw-r--r-- 1 nagios users 3.5M Sep 4 10:37 sysstat.log
-rw-r--r-- 1 nagios users 388K Sep 4 03:42 sysstat.log-20190904.gz
drwxr-xr-x. 2 nagios nagios 4.0K Aug 27 13:45 upgrades
-rw-r--r--. 1 apache apache 0 Aug 27 13:46 wkhtmltox.log
-rw-r--r--. 1 nagios nagios 7 Aug 27 13:46 xi-itype
-rw-r--r--. 1 nagios nagios 6.2K Aug 27 13:45 xi-sys.cfg
-rw-r--r--. 1 nagios nagios 37 Aug 27 13:46 xi-uuid
-rw-r--r--. 1 nagios nagios 196 Aug 27 13:45 xiversion
cat /etc/sudoers*
## Sudoers allows particular users to run various commands as
## the root user, without needing the root password.
## Examples are provided at the bottom of the file for collections
## of related commands, which can then be delegated out to particular
## users or groups.
## This file must be edited with the 'visudo' command.
## Host Aliases
## Groups of machines. You may prefer to use hostnames (perhaps using
## wildcards for entire domains) or IP addresses instead.
# Host_Alias FILESERVERS = fs1, fs2
# Host_Alias MAILSERVERS = smtp, smtp2
## User Aliases
## These aren't often necessary, as you can use regular groups
## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname
## rather than USERALIAS
# User_Alias ADMINS = jsmith, mikem
## Command Aliases
## These are groups of related commands...
## Networking
# Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclient, /usr/bin/net, /sbin/iptables, /usr/bin/rfcomm, /usr/bin/wvdial, /sbin/iwconfig, /sbin/mii-tool
## Installation and management of software
# Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
## Services
# Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig
## Updating the locate database
# Cmnd_Alias LOCATE = /usr/bin/updatedb
## Storage
# Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe, /bin/mount, /bin/umount
## Delegating permissions
# Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
## Processes
# Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
## Drivers
# Cmnd_Alias DRIVERS = /sbin/modprobe
# Defaults specification
# Refuse to run if unable to disable echo on the tty.
Defaults !visiblepw
# Preserving HOME has security implications since many programs
# use it when searching for configuration files. Note that HOME
# is already set when the the env_reset option is enabled, so
# this option is only effective for configurations where either
# env_reset is disabled or HOME is present in the env_keep list.
Defaults always_set_home
Defaults env_reset
Defaults env_keep = "COLORS DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS"
Defaults env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
Defaults env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY"
# Adding HOME to env_keep may enable a user to run unrestricted
# commands via sudo.
# Defaults env_keep += "HOME"
Defaults secure_path = /sbin:/bin:/usr/sbin:/usr/bin
## Next comes the main part: which users can run what software on
## which machines (the sudoers file can be shared between multiple
## systems).
## Syntax:
## user MACHINE=COMMANDS
## The COMMANDS section may have other options added to it.
## Allow root to run any commands anywhere
root ALL=(ALL) ALL
## Allows members of the 'sys' group to run networking, software,
## service management apps and more.
# %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LOCATE, DRIVERS
## Allows people in group wheel to run all commands
# %wheel ALL=(ALL) ALL
## Same thing without a password
# %wheel ALL=(ALL) NOPASSWD: ALL
## Allows members of the users group to mount and unmount the
## cdrom as root
# %users ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
## Allows members of the users group to shutdown this system
# %users localhost=/sbin/shutdown -h now
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_ssl_config.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
Error from running:
/usr/bin/php /usr/local/nagiosxi/cron/dbmaint.php # notice no -q
PHP Warning: unlink(/usr/local/nagiosxi/var/dbamint.lock): No such file or directory in /usr/local/nagiosxi/cron/dbmail.php on line 295
Repair Complete: FAILED TO REMOVE LOCK FILE
cdienger
Post by cdienger »
The lock file looks like it may not be getting created. What's the output of:
ll -a /usr/local/nagiosxi/var/
We can also add some code to the dbmaint.php file to check if the file is getting created. Change the init_dbmaint() function(starts on line 29) to look like:
function init_dbmaint()
    global $dbmaint_lockfile;
    // Check lock file
    if (@file_exists($dbmaint_lockfile)) {
        $ft = filemtime($dbmaint_lockfile);
        $now = time();
        if (($now - $ft) > 1800) {
            echo "LOCKFILE '".$dbmaint_lockfile."' IS OLD - REMOVING\n";
            unlink($dbmaint_lockfile);
        } else {
            echo "LOCKFILE '".$dbmaint_lockfile."' EXISTS - EXITING!\n";
            exit();
    // Create lock file
    echo "---CREATING: $dbmaint_lockfile\n";
    file_put_contents($dbmaint_lockfile, "");
        if(file_exists($dbmaint_lockfile)){
                echo "----Exists\n";}
        else{ echo "---- Does not exist\n";}
    // Make database connections
    $dbok = db_connect_all();
    if ($dbok == false) {
        echo "ERROR CONNECTING TO DATABASES!\n";
        exit();
    return;
and run the script again:
