Any idea why I can't access the API?
getting <title>404 Not Found</title>
nagiosxi.conf
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory>
Alias /nagiosxi "/usr/local/nagiosxi/html"
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
can't access api
benjaminsmith
Re: can't access api
Hello @scheived,
Just to verify, do you have API access enabled for your user account? Go to Admin > Users > Manage Users and click on your username to check.
If so, can you post the error message to the following API Call ( fill in your IP address/hostaname and API key )? Thanks.
curl -XGET "<http://ipaddress/nagiosxi/api/v1/system/status?apikey=#abc123#&pretty=1"
I was using https, change it to http and got it working now.
great!scheived wrote:I was using https, change it to http and got it working now.
Locking
