Received Root Partition Alert in Nagios
vinish098
Post by vinish098 »
Hi team,
We have configured one service with nagios like "Root Partition". There is no issue in Linux machine but getting critical alert in Nagios. Please find attached screenshot.
Please help me to explain customer about this issue.
Re: Received Root Partition Alert in Nagios
According to the image there is only 6.22% free on the root partition on the server.
This is likely below the CRITICAL threshold
The check_disk plugin which is generating the Alert, generates an alert when the disk is getting full and if the disk ran out of inodes which is happening on that partition as well.
If you run the following command as root
df -i
It will show the amount of inodes used and if is is at 100%, then that is generating the Alert as well.
If you run this command, it will Find the highest inode count on the server and then you can see what is causing the issue.
for i in /*; do echo $i; find $i |wc -l; done
