Hi Everyone
I have a question for nags core
SCENARIO :-
In th network map or the host section suppose a network switch is being monitored
The is it possible to connect to the web interface of the monitored switch from nags core screen directly
Example - suppose a Brocade switch his being monitored by Nagios core . Then when the host is opened up to view its status parameters is there anyway to connect to the web interface of the switch from this screen in nags core
Please let me know if its possible even via a plugin
Thanks and warm regards
Manoj
Connect to web interface of switch
Re: Connect to web interface of switch
This isn't possible on Nagios Core, but in Nagios XI you can add quick actions to add a link to hosts, also a "Connect to host" component which would allow RDP, VNC, Telnet, or SSH connections to the host
