Hi to everybody
I have a nagios version 4.3.4 on a Centos 7. I need to perform the following configuration and it is the following. When I make a request to http://mydomain.com I am automatically redirected to http://mydomain.com/nagios
Thank you very much in advance.
Apache configuration
pepe_carlos
Re: Apache configuration
You can make this action in your index.html of apache (usually in /var/www/html directory):
Regards
<html>
<meta HTTP-EQUIV="REFRESH" content="0; url=/nagios">
<body>
</body></html>
The above should do it, otherwise you would need to modify the apache config to have something like thispepe_carlos wrote:Hi,
RegardsCode: Select all
<html> <meta HTTP-EQUIV="REFRESH" content="0; url=/nagios"> <body> </body></html>
RewriteEngine On
RewriteRule ^/$ /nagios [L,R=301]
