Warning state when critical event
tmvision
Post by tmvision »
I have this alias configured in nsclient.ini
CheckEventLog file=application "filter=generated gt -20h AND (level eq 'error' or level eq 'warning') and source eq 'MSSQLSERVER' and message like 'backup'" unique descriptions "top-syntax=${count} message(s): ${problem_list}"
Is it possible to return only a warning state when state is critical? I've tried with the warn filter but did not work.
Any help much appreciated.
Re: Warning state when critical event
I think you need to set the crit level to blank and change the warning levels
CheckEventLog file=application "filter=generated gt -20h AND (level eq 'error' or level eq 'warning') and source eq 'MSSQLSERVER' and message like 'backup'" unique descriptions "top-syntax=${count} message(s): ${problem_list}" "warn=level in ('warning', 'error', 'critical')" "crit=level in ()"
By default they are
warning 	level = ‘warning’, problem_count > 0
critical 	level in (‘error’, ‘critical’)
tmvision
Post by tmvision »
scottwilkerson wrote:I think you need to set the crit level to blank and change the warning levels
By default they are
Thanks for the reply, however nagios shows failure:
Failed to validate filter see log for details: Warning expression is not valid: count>=level in ('warning', 'error', 'critical')
Their documentation is terrible, the only way I would see to get it to only give a warning is to set crit= to a really high value in the version I am running
for example
CheckEventLog file=application "filter=generated gt -20h AND (level eq 'error' or level eq 'warning') and source eq 'MSSQLSERVER' and message like 'backup'" unique descriptions "top-syntax=${count} message(s): ${problem_list}" "crit=999999"
tmvision
Post by tmvision »
scottwilkerson wrote:Their documentation is terrible, the only way I would see to get it to only give a warning is to set crit= to a really high value in the version I am running
for example
Yes we are using huge amounts of time to setup nagios.
Your example helped a lot, thanks.
I had to add "crit=999999" "warn=1" though, otherwise no warning would show.
tmvision wrote: Yes we are using huge amounts of time to setup nagios.
Great!
Locking thread
