How to upgrade OS on nagios xi host
ar0431
Post by ar0431 »
How to schedule down time for all host on nagios xi while we upgrade OS on nagios xi host (Redhat require reboot for kernel update)?
mbellerue
Re: How to upgrade OS on nagios xi host
Post by mbellerue »
From the Home page, go to the menu on the left, and under Incident Management select Scheduled Downtime. This will bring up a page where you can select the hosts for downtime. A trick here is that you can select the host at the top of the list, scroll all the way to the bottom, hold the Shift key, and select the host at the bottom of the list. This will select all of the hosts, and then you can click Add Selected.
chud
Post by chud »
If you are updating and rebooting the Nagios XI host itself, is that the best way to do it?
Or is there some way you can put Nagios XI into maintenance mode or something similar prior to O/S updates and reboot?
mbellerue
Post by mbellerue »
That's probably the best way to do it. But that's only based on the idea of putting a large number of hosts into scheduled downtime. What is the concern with updating and rebooting the Nagios host OS?
chud
Post by chud »
mbellerue wrote: What is the concern with updating and rebooting the Nagios host OS?
The concern is that we don't want to trigger a lot of alerts.
Also, when installing O/S patches, we are wondering if there are any dependency requirements.
mbellerue
Post by mbellerue »
You shouldn't get any invalid alerts from Nagios during an update of the OS. You could shut down Nagios if it's a concern,
service nagios stop
That would definitely stop it from alerting while you run the updates.
As far as dependencies, as long as you only have the standard repositories for the OS, your package manager should handle all of the dependencies for you.
