Hello everyone,
I don't want to start a new topic as my problem regards the one described in the above post. I downloaded the official template (OVF) of Nagios XI server and deployed it on VMware ESXi server. Initial and necessary configuration has already been done (ethernet, yum update, etc.). I followed the instruction: "How To Install & Configure The Oracle Client & Plugin", but I feel that I'm missing something..
When I go to command management and want to edit check_xi_oraclequery - according to the manual - I should edit it in the following way:
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/19.3/client64/lib ORACLE_HOME=/usr/lib/oracle/19.3/client && $USER1$/check_oracle_health $ARG1$
a. LD_LIBRARY_PATH and ORACLE_HOME are Nagios server local paths, right? Based on other article I found, $USER1 is a user-defined macro which in this case is the following path: /usr/local/nagios/libexec/
b. As for $ARG1$ - should I follow man for check_oracle_health and customize it or this is also a pre-defined macro?
c. I'm a little bit confused when it comes the packages I should install on the servers I want to monitor - I already created nagios user, generated ssh keys and added public one to authorized_keys file, I followed the instruction I mentioned above, but I still don't know what should be done there on the Oracle server - should I also download and install plugins on the Oracle server?
d. As for the above command (the one which is in bold) - how does it work exactly?
I've found Nagios very interesting and read a lot about it, but I'll need a helping hand to better understand its idea. Thank you for any tips in advance!
Oracle Monitoring Help
Re: Oracle Monitoring Help
Hey pr0t,
Now, to keep you on your toes, let's answer your last question first.
https://www.nagios.org/ncpa/
The Oracle checks will use the Oracle client tools to check on the health of Oracle. The NCPA client will help you in monitoring the health of the rest of the server.
Quick question. Are you using Nagios Core, or Nagios XI?
In any other forum, this would probably be the way to go. But here we like to keep the problems tied to a single user, and if multiple people are having the same problem, we'll type the answer up twice. But it's all good, I just spun your post off to its own thread.I don't want to start a new topic as my problem regards the one described in the above post.
What's happening with the command is that you're adding an Oracle library path to LD_LIBRARY_PATH, and setting ORACLE_HOME prior to the actual check executing. This way when the check executes, it has access to everything in those directories./usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/19.3/client64/lib ORACLE_HOME=/usr/lib/oracle/19.3/client && $USER1$/check_oracle_health $ARG1$
This is all correct.a. LD_LIBRARY_PATH and ORACLE_HOME are Nagios server local paths, right? Based on other article I found, $USER1 is a user-defined macro which in this case is the following path: /usr/local/nagios/libexec/
$ARG1$ (and $ARG2$, $ARG3$, and so on) are placeholders for arguments that will be passed to the command. This way multiple services could use the same command, but provide different arguments.b. As for $ARG1$ - should I follow man for check_oracle_health and customize it or this is also a pre-defined macro?
It's most common to install a client application, like NCPA for example.c. I'm a little bit confused when it comes the packages I should install on the servers I want to monitor - I already created nagios user, generated ssh keys and added public one to authorized_keys file, I followed the instruction I mentioned above, but I still don't know what should be done there on the Oracle server - should I also download and install plugins on the Oracle server?
Hi mbellerue,
I've followed your advice and installed NCPA client on a Windows machine. I configured it using NCPA Wizard and it works like a charm! Thank you so much!
I assume that it works the same way on any Linux.
I'm still struggling to run Oracle related checks. There was a mistake in my first post - ORACLE_HOME was supposed to be set to /usr/lib/oracle/19.3/client64. Please, correct me if I'm wrong here - Oracle checks are based on local (i.e. nagios) binaries or do I have to install any additional plugins on my Oracle servers?
BTW. By default, in the nagios core command configuration for check_xi_oraclequery we have the following: $USER1$/check_oracle_health $ARG1$ - there is no such a binary file in /usr/local/nagios/libexec/ - there's only check_oracle - is it supposed to be that way?
Regards,
I'm using Nagios XI.Quick question. Are you using Nagios Core, or Nagios XI?
Regards,
Yes, NCPA will function the same way on Linux.pr0t wrote:Hi mbellerue,
I've followed your advice and installed NCPA client on a Windows machine. I configured it using NCPA Wizard and it works like a charm! Thank you so much!I assume that it works the same way on any Linux.
Yes, the plugins live on the Nagios server in /usr/local/nagios/libexec/. It's odd that the other Oracle plugins aren't there. Have you run through the Oracle configuration wizards yet? That may be the point where they get installed.I'm still struggling to run Oracle related checks. There was a mistake in my first post - ORACLE_HOME was supposed to be set to /usr/lib/oracle/19.3/client64. Please, correct me if I'm wrong here - Oracle checks are based on local (i.e. nagios) binaries or do I have to install any additional plugins on my Oracle servers?
Regards,
