Hello Team,
It has been quite some time and hope all is well on your end. It seems as though i was having a DB error which i tried to run the repair script on and it was unable to start mysqld. I tried restarting all services in order and noticed postresql failing to start as well. I tried to run the same type of repair that would occur after the disks get full (was not the case just thought a clean start would help) just to clear everything out and didnt get anywhere there either. Reboot didnt help either, think i tried that somewhere inbetween the other stuff. Let me know what i should try next.
Thank you,
Matt
Postgresql and msqld fail to start
Re: Postgresql and msqld fail to start
Hi Matt,
First, do you know if your Nagios databases are hosted on MySQL or PostgreSQL?
Next, go ahead and try to start the database. Then when it fails run,
and send us the output.
journalctl -xeAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
matt.lilek
[root@ATT3-NAG1 ~]# journalctl -xe
bash: journalctl: command not found
Yikes. What OS is this?
We can do it the hard way and do,
We'll see if we can find anything related to the failed startup in there.
There may also be something in,
Assuming the Nagios databases actually live in MySQL rather than Postgres.
tail -20 /var/log/syslogThere may also be something in,
tail -20 /var/log/mysql/error.logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
matt.lilek
Linux ATT3-NAG1.global.amec.com 2.6.32-754.10.1.el6.x86_64 #1 SMP Tue Jan 15 17:07:28 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Am i doing something horribly wrong here, lol
[root@ATT3-NAG1 ~]# tail -20 /var/log/syslog
tail: cannot open `/var/log/syslog' for reading: No such file or directory
[root@ATT3-NAG1 ~]# tail -20 /var/log/mysql/error.log
tail: cannot open `/var/log/mysql/error.log' for reading: No such file or directory
Nope, you're doing everything right. I'm giving you file locations and commands for newer versions of Linux. That's my bad. Let's try this again.
tail -20 /var/log/messages
tail -20 /var/log/mysqld.logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
matt.lilek
Sep 9 22:53:14 ATT3-NAG1 ntpd[1800]: Listen normally on 5 eth0 fe80::250:56ff:fea2:79e1 UDP 123
Sep 9 22:53:14 ATT3-NAG1 ntpd[1800]: Listening on routing socket on fd #22 for interface updates
Sep 9 22:53:19 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c016 06 restart
Sep 9 22:53:19 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c012 02 freq_set kernel 0.000 PPM
Sep 9 22:53:19 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c011 01 freq_not_set
Sep 9 22:53:25 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c61c 0c clock_step -0.383738 s
Sep 9 22:53:25 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c614 04 freq_mode
Sep 9 22:53:26 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c618 08 no_sys_peer
Sep 9 22:55:18 ATT3-NAG1 nrpe[26281]: Starting up daemon
Sep 9 22:55:18 ATT3-NAG1 nrpe[26281]: Server listening on 0.0.0.0 port 5666.
Sep 9 22:55:18 ATT3-NAG1 nrpe[26281]: Server listening on :: port 5666.
Sep 9 22:55:18 ATT3-NAG1 nrpe[26281]: Listening for connections on port 5666
Sep 9 22:55:18 ATT3-NAG1 nrpe[26281]: Allowing connections from: 127.0.0.1,::1
Sep 9 22:55:20 ATT3-NAG1 ndo2db: Warning: Unable to write pid to lockfile (errno 28): No space left on device
Sep 9 23:00:27 ATT3-NAG1 init: tty (/dev/tty1) main process ended, respawning
Sep 9 23:07:47 ATT3-NAG1 ndo2db: Warning: Unable to write pid to lockfile (errno 28): No space left on device
Sep 9 23:08:32 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c612 02 freq_set kernel 16.025 PPM
Sep 9 23:08:32 ATT3-NAG1 ntpd[1800]: 0.0.0.0 c615 05 clock_sync
Sep 9 23:14:07 ATT3-NAG1 ndo2db: Warning: Unable to write pid to lockfile (errno 28): No space left on device
Sep 9 23:34:07 ATT3-NAG1 ndo2db: Warning: Unable to write pid to lockfile (errno 28): No space left on device
[root@ATT3-NAG1 ~]# tail -20 /var/log/mysqld.log
InnoDB: buffer...
190910 5:04:40 InnoDB: Started; log sequence number 0 48336
190910 5:04:40 [ERROR] /usr/libexec/mysqld: Error writing file '/var/run/mysqlmysqld.pid' (Errcode: 28)
190910 5:04:40 [ERROR] Can't start server: can't create PID file: No space lefon device
190910 05:04:40 mysqld_safe Number of processes running now: 0
190910 05:04:40 mysqld_safe mysqld restarted
190910 5:04:41 InnoDB: Initializing buffer pool, size = 8.0M
190910 5:04:41 InnoDB: Completed initialization of buffer pool
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
190910 5:04:41 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
190910 5:04:41 InnoDB: Started; log sequence number 0 48336
190910 5:04:41 [ERROR] /usr/libexec/mysqld: Error writing file '/var/run/mysqlmysqld.pid' (Errcode: 28)
190910 5:04:41 [ERROR] Can't start server: can't create PID file: No space lefon device
190910 05:04:41 mysqld_safe Number of processes running now: 0
190910 05:04:41 mysqld_safe mysqld restarted
InnoDB: buffer...
InnoDB: buffer...
Looks like you're out of space. What does df say?
df -hAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
