Nagios JSON Query Generator as CURL
anilgupta
Post by anilgupta »
Team,
I am trying to get server/service status programmatically.
I got the query from Nagios JSON Query Generator, like https://intra.dev.eiamreporting.cac.gov ... .gov.on.ca. I am expecting the output similar to JSON Query Generator, shown below:
URL: https://intra.dev.eiamreporting.cac.gov ... .gov.on.ca
"format_version": 0,
"result": {
"query_time": 1568066510000,
"cgi": "statusjson.cgi",
"user": "nagiosadmin",
"query": "host",
"query_status": "released",
"program_start": 1568062349000,
"last_data_update": 1568066509000,
"type_code": 0,
"type_text": "Success",
"message": ""
"data": {
"host": {
"name": "csbtipdcapmdw05.service.cihs.gov.on.ca",
"plugin_output": "OK - 10.92.34.49: rta 1.139ms, lost 0%",
"long_plugin_output": "",
"perf_data": "rta=1.139ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=1.427ms;;;; rtmin=0.874ms;;;;",
"status": 2,
"last_update": 1568066508000,
"has_been_checked": true,
"should_be_scheduled": true,
"current_attempt": 1,
"max_attempts": 5,
"last_check": 1568066449000,
"next_check": 1568066749000,
"check_options": 0,
"check_type": 0,
"last_state_change": 1567320426000,
"last_hard_state_change": 1558013145000,
"last_hard_state": 0,
"last_time_up": 1568066449000,
"last_time_down": 1567320426000,
"last_time_unreachable": 0,
"state_type": 1,
"last_notification": 0,
"next_notification": 0,
"no_more_notifications": false,
"notifications_enabled": true,
"problem_has_been_acknowledged": false,
"acknowledgement_type": 0,
"current_notification_number": 0,
"accept_passive_checks": true,
"event_handler_enabled": true,
"checks_enabled": true,
"flap_detection_enabled": true,
"is_flapping": false,
"percent_state_change": 0,
"latency": 0,
"execution_time": 0.01,
"scheduled_downtime_depth": 0,
"process_performance_data": true,
"obsess": true
However, when I try it from CURL, it throws weird output.
[guptaa2.on34c02621424] ➤ curl -vk --user monitor:xxxxxxx https://intra.dev.eiamreporting.cac.gov ... .gov.on.ca
[1] 26960
[2019-09-09 18:12.35] ~
[guptaa2.on34c02621424] ➤ * Trying 10.194.11.23...
* TCP_NODELAY set
* Connected to intra.dev.eiamreporting.cac.gov.on.ca (10.194.11.23) port 443 (#0)
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* error setting certificate verify locations, continuing anyway:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* Server certificate:
* subject: C=CA; ST=Ontario; L=Toronto; O=Government of Ontario; CN=intra.dev.eiamreporting.cac.gov.on.ca
* start date: Mar 29 17:49:12 2019 GMT
* expire date: Mar 29 18:19:11 2021 GMT
* issuer: C=US; O=Entrust, Inc.; OU=See http://www.entrust.net/legal-terms; OU=(c) 2012 Entrust, Inc. - for authorized use only; CN=Entrust Certification Authority - L1K
* SSL certificate verify result: self signed certificate in certificate chain (19), continuing anyway.
* Server auth using Basic with user 'monitor'
> GET /nagios/cgi-bin/statusjson.cgi?query=host HTTP/1.1
> Host: intra.dev.eiamreporting.cac.gov.on.ca
> Authorization: Basic bW9uaXRvcjphZG00bW9uaXRvcg==
> User-Agent: curl/7.50.3
> Accept: */*
< HTTP/1.1 200 OK
< Date: Mon, 09 Sep 2019 22:12:35 GMT
< Server: Apache/2.4.6 (Red Hat Enterprise Linux) OpenSSL/1.0.2k-fips PHP/5.4.16
< Cache-Control: no-store
< Pragma: no-cache
< Expires: Thu, 01 Jan 1970 00:00:00 GMT
< Last-Modified: Mon, 09 Sep 2019 22:12:35 GMT
< Transfer-Encoding: chunked
< Content-Type: application/json; charset=utf-8
"result": {
"query_time": 1568067155000,
"query": "host",
"type_code": 4,
"type_text": "Option Missing",
"message": "Host information requested, but no host name specified."
"data": {
"options": {
"query": {
"label": "Query",
"type": "enumeration",
"required": [
"all"
"optional": [
"depends_on": "",
"description": "Specifies the type of query to be executed.",
"valid_values": {
"hostcount": {
"description": "Return the number of hosts in each state"
"hostlist": {
"description": "Return a list of hosts and their current status"
"host": {
"description": "Return the status of a single host."
"servicecount": {
"description": "Return the number of services in each state"
"servicelist": {
"description": "Return a list of services and their current status"
"service": {
"description": "Return the status of a single service"
"commentcount": {
"description": "Return the number of comments"
"commentlist": {
"description": "Return a list of comments"
"comment": {
"description": "Return a single comment"
"downtimecount": {
"description": "Return the number of downtimes"
"downtimelist": {
"description": "Return a list of downtimes"
"downtime": {
"description": "Return a single downtime"
"programstatus": {
"description": "Return the Nagios Core program status"
"performancedata": {
"description": "Return the Nagios Core performance data"
"help": {
"description": "Display help for this CGI"
"formatoptions": {
"label": "Format Options",
"type": "list",
"required": [
"optional": [
"all"
"depends_on": "",
"description": "Specifies the formatting options to be used when displaying the results. Multiple options are allowed and are separated by a plus (+) sign..",
"valid_values": {
"whitespace": {
"description": "Pad with whitespace to increase readability"
"enumerate": {
"description": "Use textual representations of enumerated values rather than raw numeric values"
"bitmask": {
"description": "Use textual representations of bitmask values rather than raw numeric values"
"duration": {
"description": "Use textual representations (xd xh xm xs) of duration values rather than raw number of seconds"
"start": {
"label": "Start",
"type": "integer",
"required": [
"optional": [
"hostlist",
"servicelist"
"depends_on": "",
"description": "Specifies the index (zero-based) of the first object in the list to be returned."
"count": {
"label": "Count",
"type": "integer",
"required": [
"optional": [
"hostlist",
"servicelist"
"depends_on": "",
"description": "Specifies the number of objects in the list to be returned."
"parenthost": {
"label": "Parent Host",
"type": "nagios:objectjson/hostlist",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits the hosts or services returned to those whose host parent is specified. A value of 'none' returns all hosts or services reachable directly by the Nagios core host.",
"valid_values": {
"none": {
"description": "Hosts that are directly reachable by the Nagios Core host"
"childhost": {
"label": "Child Host",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits the hosts or services returned to those whose having the host specified as a child host. A value of 'none' returns all hosts or services with no child hosts.",
"valid_values": {
"none": {
"description": "Hosts that have no child hosts"
"details": {
"label": "Show Details",
"type": "boolean",
"required": [
"optional": [
"hostlist",
"servicelist",
"commentlist",
"downtimelist"
"depends_on": "",
"description": "Returns the details for all entities in the list."
"dateformat": {
"label": "Date Format",
"type": "string",
"required": [
"optional": [
"all"
"depends_on": "",
"description": "strftime format string for values of type time_t. In the absence of a format, the Javascript default format of the number of milliseconds since the beginning of the Unix epoch is used. Because of URL encoding, percent signs must be encoded as %25 and a space must be encoded as a plus (+) sign."
"hostname": {
"label": "Host Name",
"required": [
"host",
"service"
"optional": [
"servicecount",
"servicelist",
"commentcount",
"commentlist",
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Name for the host requested."
"hostgroup": {
"label": "Host Group",
"type": "nagios:objectjson/hostgrouplist",
"required": [
"hostgroup"
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Returns information applicable to the hostgroup or the hosts in the hostgroup depending on the query."
"hoststatus": {
"label": "Host Status",
"type": "list",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits returned information to those hosts whose status matches this list. Host statuses are space separated.",
"valid_values": {
"up": {
"description": "HOST_UP"
"down": {
"description": "HOST_DOWN"
"unreachable": {
"description": "HOST_UNREACHABLE"
"pending": {
"description": "HOST_PENDING"
"servicegroup": {
"label": "Service Group",
"type": "nagios:objectjson/servicegrouplist",
"required": [
"servicegroup"
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Returns information applicable to the servicegroup or the services in the servicegroup depending on the query."
"servicestatus": {
"label": "Service Status",
"type": "list",
"required": [
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits returned information to those services whose status matches this list. Service statuses are space separated.",
"valid_values": {
"ok": {
"description": "SERVICE_OK"
"warning": {
"description": "SERVICE_WARNING"
"critical": {
"description": "SERVICE_CRITICAL"
"unknown": {
"description": "SERVICE_UNKNOWN"
"pending": {
"description": "SERVICE_PENDING"
"parentservice": {
"label": "Parent Service",
"type": "nagios:objectjson/servicelist",
"required": [
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits the services returned to those whose service parent has the name specified. A value of 'none' returns all services with no service parent.",
"valid_values": {
"none": {
"description": "Services that have no parent services"
"childservice": {
"label": "Child Service",
"required": [
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Limits the services returned to those whose having the named service as a child service. A value of 'none' returns all services with no child services.",
"valid_values": {
"none": {
"description": "Services that have no child services"
"contactgroup": {
"label": "Contact Group",
"type": "nagios:objectjson/contactgrouplist",
"required": [
"contactgroup"
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Returns information applicable to the contactgroup or the contacts in the contactgroup depending on the query."
"servicedescription": {
"label": "Service Description",
"required": [
"service"
"optional": [
"servicecount",
"servicelist",
"commentcount",
"commentlist",
"downtimecount",
"downtimelist"
"depends_on": "hostname",
"description": "Description for the service requested."
"checktimeperiod": {
"label": "Check Timeperiod Name",
"type": "nagios:objectjson/timeperiodlist",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Name of a check timeperiod to be used as selection criteria."
"hostnotificationtimeperiod": {
"label": "Host Notification Timeperiod Name",
"required": [
"optional": [
"hostcount",
"hostlist"
"depends_on": "",
"description": "Name of a host notification timeperiod to be used as selection criteria."
"servicenotificationtimeperiod": {
"label": "Service Notification Timeperiod Name",
"required": [
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Name of a service notification timeperiod to be used as selection criteria."
"checkcommand": {
"label": "Check Command Name",
"type": "nagios:objectjson/commandlist",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Name of a check command to be be used as a selector."
"eventhandler": {
"label": "Event Handler Name",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Name of an event handler to be be used as a selector."
"commenttypes": {
"label": "Comment Type",
"type": "list",
"required": [
"optional": [
"commentcount",
"commentlist"
"depends_on": "",
"description": "Comment type for the comment requested.",
"valid_values": {
"host": {
"description": "Host Comment"
"service": {
"description": "Service Comment"
"entrytypes": {
"label": "Entry Type",
"type": "list",
"required": [
"optional": [
"commentcount",
"commentlist"
"depends_on": "",
"description": "Entry type for the comment requested.",
"valid_values": {
"user": {
"description": "User Comment"
"downtime": {
"description": "Downtime Comment"
"flapping": {
"description": "Flapping Comment"
"acknowledgement": {
"description": "Acknowledgement Comment"
"persistence": {
"label": "Comment Persistence",
"type": "list",
"required": [
"optional": [
"commentcount",
"commentlist"
"depends_on": "",
"description": "Persistence for the comment requested.",
"valid_values": {
"yes": {
"description": "Persistent Comment"
"no": {
"description": "Non-Persistent Comment"
"expiring": {
"label": "Comment Expiration",
"type": "list",
"required": [
"optional": [
"commentcount",
"commentlist"
"depends_on": "",
"description": "Whether or not the comment expires.",
"valid_values": {
"yes": {
"description": "Comment Expires"
"no": {
"description": "Comment Does Not Expire"
"downtimeobjecttypes": {
"label": "Downtime Object Type",
"type": "list",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "The type of object to which the downtime applies.",
"valid_values": {
"host": {
"description": "Host Downtime"
"service": {
"description": "Service Downtime"
"downtimetypes": {
"label": "Downtime Type",
"type": "list",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "The type of the downtime.",
"valid_values": {
"fixed": {
"description": "Fixed Downtime"
"flexible": {
"description": "Flexible Downtime"
"triggered": {
"label": "Downtime Triggered",
"type": "list",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Whether or not the downtime is triggered.",
"valid_values": {
"yes": {
"description": "Downtime Triggered"
"no": {
"description": "Downtime Not Triggered"
"triggeredby": {
"label": "Triggered By",
"type": "nagios:statusjson/downtimelist",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "ID of the downtime which triggers other downtimes."
"ineffect": {
"label": "Downtime In Effect",
"type": "list",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Whether or not the downtime is in effect.",
"valid_values": {
"yes": {
"description": "Downtime In Effect"
"no": {
"description": "Downtime Not In Effect"
"commentid": {
"label": "Comment ID",
"type": "nagios:statusjson/commentlist",
"required": [
"comment"
"optional": [
"depends_on": "",
"description": "Comment ID for the comment requested."
"downtimeid": {
"label": "Downtime ID",
"required": [
"downtime"
"optional": [
"depends_on": "",
"description": "Downtime ID for the downtime requested."
"contactname": {
"label": "Contact Name",
"type": "nagios:objectjson/contactlist",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist"
"depends_on": "",
"description": "Name for the contact requested."
"hosttimefield": {
"label": "Host Time Field",
"required": [
"optional": [
"hostcount",
"hostlist"
"depends_on": "",
"description": "Field to use when comparing times on a hostlist query.",
"valid_values": {
"lastupdate": {
"description": "Last Update"
"lastcheck": {
"description": "Last Check"
"nextcheck": {
"description": "Next Check"
"laststatechange": {
"description": "Last State Change"
"lasthardstatechange": {
"description": "Last Hard State Change"
"lasttimeup": {
"description": "Last Time Up"
"lasttimedown": {
"description": "Last Time Down"
"lasttimeunreachable": {
"description": "Last Time Unreachable"
"lastnotification": {
"description": "Last Notification"
"nextnotification": {
"description": "Next Notification"
"servicetimefield": {
"label": "Service Time Field",
"required": [
"optional": [
"servicecount",
"servicelist"
"depends_on": "",
"description": "Field to use when comparing times on a servicelist query.",
"valid_values": {
"lastupdate": {
"lastcheck": {
"nextcheck": {
"lasttimeok": {
"description": "Last Time OK"
"lasttimewarning": {
"description": "Last Time Warning"
"lasttimecritical": {
"description": "Last Time Critical"
"lasttimeunknown": {
"description": "Last Time Unknown"
"commenttimefield": {
"label": "Comment Time Field",
"required": [
"optional": [
"commentcount",
"commentlist"
"depends_on": "",
"description": "Field to use when comparing times on a commentlist query.",
"valid_values": {
"entrytime": {
"description": "Entry Time"
"expiretime": {
"description": "Expiration Time"
"downtimetimefield": {
"label": "Downtime Time Field",
"required": [
"optional": [
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Field to use when comparing times on a downtimelist query.",
"valid_values": {
"entrytime": {
"starttime": {
"description": "Start Time"
"flexdowntimestart": {
"description": "Flex Downtime Start"
"endtime": {
"description": "End Time"
"starttime": {
"label": "Start Time",
"type": "integer",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist",
"commentcount",
"commentlist",
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Starting time to use when querying based on a time range. Not specifying a start time implies all entries since the beginning of time. Supplying a plus or minus sign means times relative to the query time."
"endtime": {
"label": "End Time",
"type": "integer",
"required": [
"optional": [
"hostcount",
"hostlist",
"servicecount",
"servicelist",
"commentcount",
"commentlist",
"downtimecount",
"downtimelist"
"depends_on": "",
"description": "Ending time to use when querying based on a time range. Not specifying an end time implies all entries until the time of the query. Specifying plus or minus sign means times relative to the query time."
* Curl_http_done: called premature == 0
* Connection #0 to host intra.dev.eiamreporting.cac.gov.on.ca left intact
─────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────[1]+ Done /bin/curl.exe -vk --user monitor:adm4monitor https://intra.dev.eiamreporting.cac.gov ... query=host
[2019-09-09 18:12.38] ~
I seek your help to understand if it is correct way to achieve the status. If not then recommend the proper way.
Re: Nagios JSON Query Generator as CURL
You need to wrap the URL in quotes in the curl command because of the special chars
curl -vk --user monitor:xxxxxxx "https://intra.dev.eiamreporting.cac.gov.on.ca/nagios/cgi-bin/statusjson.cgi?query=host&hostname=csbtipdcapmdw05.service.cihs.gov.on.ca"
anilgupta
Post by anilgupta »
oh silly me!
Thanks a lot!
anilgupta wrote:oh silly me!
Thanks a lot!
No worries.
Locking thread
