BPI Error
sagesoft
BPI Error
Post by sagesoft »
Need assistance on encountered BPI "BPI unknown Group Index" in version 5.6.6.
Refer attached Screenshot.
benjaminsmith
Re: BPI Error
Post by benjaminsmith »
Hello @Brezner,
Can you PM the following files and your system profile so we can take a closer look? Thanks.
/usr/local/nagiosxi/var/components/bpi.log
/usr/local/nagiosxi/etc/components/bpi.conf
/usr/local/nagiosxi/etc/components/bpi.conf.backup
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message and then reply to this post to bring it up in the queue.
sagesoft
Re: BPI Error
Post by sagesoft »
You can locked this ticket since this is already resolved via remote session. Thank you for your support.
benjaminsmith
Re: BPI Error
Hello @brezner,
Thanks for the update and happy to it's been resolved.
