Can't get check_nrpe or check_nt to work on a Windows Host
craigtho
Post by craigtho »
Hi all,
So I configured my own Nagios core server (version 4.4.3) on Ubuntu 18.04 LTS VM. I have set it up to monitor most of the hosts on my infra, both Linux & Windows.
On my web interface, I can see that my machine I'm monitoring has picked up all the defined check_nt services I have listed in my .cfg directory:
https://imgur.com/a/CG1uE6h
The hosts .cfg file is as follows:
nsclient.ini
nsclient.ini
(7.13 KiB) Downloaded 123 times
When I run the same commands on the termial however, it get a timeout error. Adding the -t flag doesn't help either:
https://imgur.com/a/hY9ccdK
nsclient.ini here:
nsclient.ini
nsclient.ini
my-pc.cfg
my.cfg
(3.99 KiB) Downloaded 134 times
Re: Can't get check_nrpe or check_nt to work on a Windows Ho
You need to add the port (-p 12489)
/usr/local/nagios/libexec/check_nt -H 192.168.60.41 -p 12489 -v CLIENTVERSION
craigtho
Post by craigtho »
Damn...
Well, post closed.
I'm still getting issues using NRPE on the Windows host, but ill post that seperately.
craigtho wrote:Damn...
Well, post closed.
ok
Locking
