API for alerts and events
abhishekkayal89
Post by abhishekkayal89 »
is there any api for getting device deatils and logentries together
Re: API for alerts and events
Yes in XI under
Help -> Objects Reference
abhishekkayal89
objects/logentries gives events and alerts
but i am looking for respective device details along with it how to get in single api call
abhishekkayal89
or can we correlate the data from objects/logentries api with any other api available in Nagios XI api objects to get device details
abhishekkayal89 wrote:objects/logentries gives events and alerts
You cannot do it in a single call, you can get status from:
GET objects/hoststatus
GET objects/servicestatus
abhishekkayal89
but how i will relate the logentries api results with hostlist results to determine which alert is for which device
The API isn't written to do this correlation, the best I can suggest would be to search the host names in the logs.
