Hi all.
I have installed nagios 4.4.3 on centos 7 from yum.
I would like to test NERD functionality but it seems it does not start correctly. As you can see from log, nerd hostchecks and servicechecks are not registered and not available to be queried.
Why NERD is not started ? What I need to check ?
Thanks for helping !!
Giovanni
[1568706166] Nagios 4.4.3 starting... (PID=39121)
[1568706166] Local time is Tue Sep 17 09:42:46 CEST 2019
[1568706166] LOG VERSION: 2.0
[1568706166] qh: Socket '/var/spool/nagios/cmd/nagios.qh' successfully initialized
[1568706166] qh: core query handler registered
[1568706166] qh: echo service query handler registered
[1568706166] qh: help for the query handler registered
[1568706166] wproc: Successfully registered manager as @wproc with query handler
[1568706166] wproc: Registry request: name=Core Worker 39125;pid=39125
NERD is not registered
Re: NERD is not registered
nerd is disabled by default.
You need to compile from source and enable with --enable-nerd during ./configure
Source install instructions can be found here
https://support.nagios.com/kb/article/n ... ce-96.html
Thanks for answer ... so it is impossible to enable NERD within a yum package ?
Thanks a lot
Thanks a lot
that would be correctmrroger wrote:Thanks for answer ... so it is impossible to enable NERD within a yum package ?
Thanks a lot
