I'd like to be able to do passive checks while host_down_disable_service_checks is enabled, is that possible ?
(https://support.nagios.com/forum/viewto ... 20#p292425)
We decided it shouldn't negate the performance benefits we get from host_down_disable_service_checks as it would only do one passive service check per service instead of one every x minutes if host_down_disable_service_checks is not enabled.
But it doesn't seem to work when done through nagios xi ui and when done using a script aswell.
Also, the checks are done by gearman workers.
The eventhandler script would look something like this, right ?
#!/bin/bash
HOSTNAME=$1
HOSTSTATE=$2
SERVICENAME=$3
DATE=$(date)
COMMANDFILE='/usr/local/nagios/var/rw/nagios.cmd'
case "$HOSTSTATE" in
DOWN)
/bin/printf "[%lu] PROCESS_SERVICE_CHECK_RESULT;$HOSTNAME;$SERVICENAME;2;CRITICAL" $DATE > $COMMANDFILE
esac
