Hello Team,
I have been observed several times that the database of our nagios server "https://cloudmon.ccb.cloudwifi.com/nagiosxi/" is crashing very frequently even not possible to ssh to the nagios server and have to repair database using below command after relaunching it.
/usr/local/nagiosxi/scripts/repair_databases.sh
Attaching image which shows nagios crashing behavior.
Please let us know what information you require to investigate it further.
Bharat Lalwani
Nagios is crashing again and again
arista-nagios
benjaminsmith
Re: Nagios is crashing again and again
Hello @arista-nagios,
A few questions to help us troubleshoot this issue. Please post the output to the commands below.
1. How is the disk space on the server?
2. Post the output to the following query to check the sizes of the database tables.
3. Run through the following commands to re-start nagios, repair the databases, and then send us your system profile. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share in a private message and then reply to this post to bring it up in the queue.
df -h
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
systemctl stop crond
systemctl stop npcd
systemctl stop nagios
systemctl stop ndo2db
pkill -9 -u nagios
for i in $(ipcs -q | grep nagios |awk '{print $2}'); do ipcrm -q $i; done
rm -rf /usr/local/nagiosxi/var/dbmaint.lock
rm -rf /usr/local/nagiosxi/var/event_handler.lock
rm -rf /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
systemctl restart mysqld || systemctl restart mariadb
./repair_databases.sh
systemctl start npcd
systemctl start crond
systemctl start nagios
systemctl start ndo2db
