check_telnet throwing errors
rjmon
Post by rjmon »
I just installed check_telnet.pl and i tried to test i am getting
Can't call method "close" on an undefined value at ./check_telnet.pl line 120.
Any ideas..
Re: check_telnet throwing errors
Not sure where this plugin came from as it is not part of the Nagios Plugins package, so we are unfamiliar with it.
You may want to look for the author who would be better suited to answer the question
