Nagios Fusion - Auto-Login
This support forum board is for questions relating to Nagios Fusion.
dbcummings
Post by dbcummings »
Is there a way to create an auto-login for Nagios fusion? We have a viewer only account for our Nagios XI servers. We want to do the same for Nagios Fusion.
Re: Nagios Fusion - Auto-Login
At present this is not available, but I could submit a feature request if you like for possible inclusion in a future versions
dbcummings
Yes, please. Unfortunately, we can't use Fusion as it is currently configured.
Feature request added ID #12397
dbcummings
Is there any way I can disable authentication on Fusion in the short term?
dbcummings wrote:Is there any way I can disable authentication on Fusion in the short term?
Unfortunately no, Fusion needs to establish a session to know which account to use, and that is created at login
dbcummings
Thanks. I appreciate the info. You can close this as long as there is an ER for the functionality. We will probably not use Fusion until it is a more mature product.
dbcummings wrote:Thanks. I appreciate the info. You can close this as long as there is an ER for the functionality. We will probably not use Fusion until it is a more mature product.
Great!
Locking thread
