Need help configuring SSL with Nagios XI
tgfde
Post by tgfde »
I'm trying to configure SSL with Nagios XI by following the documentation (Nagios XI - Configuring SSL with Nagios XI) from Nagios but having a problem copying the three files (ca.crt, ca.key, ca.csr). When executing the cp command, it tells me "No such file or directory". So I tried to locate the file with the locate command but received no result.
FYI - I installed mod_ssl and generated the key with no problem.
Thanks in advanced.
Re: Need help configuring SSL with Nagios XI
After running these commands:
openssl genrsa -out ca.key 2048
openssl req -new -key ca.key -out ca.csr
openssl x509 -req -days 365 -in ca.csr -signkey ca.key -out ca.crt
you should have "ca.crt", "ca.key", and "ca.csr" files created in the directory you are currently in.
Go to the "tmp" directory and try running these commands again.
cd /tmp
The newly generated files should be in the "/tmp" directory now.
F.Y.I. Sometimes, locate would not find a new file - you will have to run "updatedb" first.
Hope this helps.
tgfde
Post by tgfde »
Hi lmiltchev.
I ran the commands again from /tmp directory and it worked. However, it did not create the ca.crt file.
Frederick
