question about the status of service
I got a problem about the status of service while using "check_oracle_health" command.
the return of "check_oracle_health" command is OK, but the status of service is "Warning" as following picture. the result of running command is also OK. the status of service should be OK, but it is Warning.
what should I check first about the setting?
Many thanks in advance!
Best regards!
Best regards!
Re: question about the status of service
Can you run the following command after you run your check from the CLI, and show the output?
Also, show the output of:
echo $?Code: Select all
ps -ef | grep nagios.cfg | grep -v grepBe sure to check out our Knowledgebase for helpful articles and solutions!
lmiltchev wrote:Can you run the following command after you run your check from the CLI, and show the output?Also, show the output of:Code: Select all
Thank you very much for your reply.
Following you can see the result of running the commands.
benjaminsmith
Hello @shikpp,
Are you receiving notifications as well for the service? If not, then the monitoring engine must be processing the service as OK and the information in the dashlet is not getting populated correctly.
Can you send us your system profile so we can take a closer look at the system. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
benjaminsmith wrote:Hello @shikpp,
hi benjaminsmith,
Thank you for your reply!
A notification was also sent while the result was OK. And attached you can find the profile.zip.
Best regards,
ShiKe
Moderator's Note: The profile has been shared with the Nagios Support team, and has been removed from the public forum.
benjaminsmith
Hello @shikpp,
Thanks for sending over your system profile. Did you always have issues with this plugin or was it working correctly. We noticed the configuration file for oracle host is not in the configuration hosts directory where it is normally stored.
Please remove all the files inside the /var/tmp/check_oracle_health directory, and make sure the nagios user has permissions to write to this directory.
Check the permissions
Next try running the check command from the terminal as before but this time please log in as the nagios user (instead of root) and post the output.
ls -ld /var/tmp/check_oracle_health
su nagios
hi benjaminsmith,benjaminsmith wrote:Hello @shikpp,
Check the permissionsNext try running the check command from the terminal as before but this time please log in as the nagios user (instead of root) and post the output.Code: Select all
ls -ld /var/tmp/check_oracle_healthCode: Select all
su nagios
the nagios user has the write right to the directory "/var/tmp/check_oracle_health". the result is as following screenshot. This plugin is working well in the version 5.5.11 and attached you can find the profile of 5.5.11.
Best regards,
shike
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
First, clear out the temp files by running this.
Then run the plugin as the nagios user by running the following in a shell. Post the full output
Also, run this to get the version of the plugin and post it here.
If the above tests show the correct status from the command line, go to the GUI and force the check to run and see if the status is updated there.
rm -fr /var/tmp/check_oracle_health/*Code: Select all
su - nagios
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect 'oracle:1521/tc9' --username 'infodba' --password 'infodba' --mode sga-dictionary-cache-hit-ratio --warning 98: --critical 95:
echo $
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect='oracle:1521/tc9' --username='infodba' --password='infodba' --mode=connection-time --warning=1 --critical=5
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --versionIf the above tests show the correct status from the command line, go to the GUI and force the check to run and see if the status is updated there.
Hi tgriep,tgriep wrote:First, clear out the temp files by running this.Then run the plugin as the nagios user by running the following in a shell. Post the full outputCode: Select all
rm -fr /var/tmp/check_oracle_health/*It seems that there is something error while running service command by using "nagios" account, could you tell me where i can find the log fileCode: Select all
su - nagios /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect 'oracle:1521/tc9' --username 'infodba' --password 'infodba' --mode sga-dictionary-cache-hit-ratio --warning 98: --critical 95: echo $ /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect='oracle:1521/tc9' --username='infodba' --password='infodba' --mode=connection-time --warning=1 --critical=5 echo $?
Also, run this to get the version of the plugin and post it here.If the above tests show the correct status from the command line, go to the GUI and force the check to run and see if the status is updated there.Code: Select all
please see the result of commands above.
The status is updated while forcing running the check in GUI. Many thanks in advance!
Best regards,
shike
The version of the plugin you are running is over 5 years old and you should update it to the latest version.
You can get it at the following link. It also has instructions for installing it.
https://labs.consol.de/nagios/check_ora ... index.html
