No matching host found
dburke
Post by dburke »
I installed xi on my Oracle V box on which I am running three VMs one set up as Nagios host and two clients. Everything installed fine, but i am unable to get the two clients to show up on the Host Detail / service Detail screen. I get the message: No matching host found
However the two clients shows up as added on the CCM screen 2 hosts and 25 Services
Any ideas what causing this?
mbellerue
Re: No matching host found
Post by mbellerue »
The very first thing to check here would be that the configuration was applied. Head back to Configure -> Core Config Manager. The top link of the left menu is Apply Configuration. If it's red, there are configuration changes that need to be applied. Click that link, and the subsequent Apply Configuration button. Then check to see if your hosts show up.
The next thing to check will be the config files. In Configure -> Core Config Manager, in the left menu towards the bottom under the Tools subheading is Config File Management. Click the Delete Files button, followed by the Write Configs button, followed by the Verify Files button. If the files verify, go ahead and hit the Restart Nagios Core button. Then see if your hosts show up.
If those don't work, let us know, and we'll dig deeper.
