PHP warning in nagiosim.inc.php on line 491
xdatanet
Post by xdatanet »
During every upgrade, at the end, I find this warning...
I've checked the postgre database. If I run the query it returns one row...
You are now connected to database "nagiosxi".
nagiosxi=# SELECT COUNT(relname) FROM pg_class WHERE relname = 'xi_incidents';
 count
     1
(1 row)
What did I miss??
Regards,
Graziano.
Re: PHP warning in nagiosim.inc.php on line 491
This is from an old integration for a product that is no longer available. You can safely remove the integration with the following command eliminating the warning
rm -rf /usr/local/nagiosxi/html/includes/components/nagiosim
xdatanet
Post by xdatanet »
This makes sense.
Thanks.
Regards,
Graziano.
xdatanet wrote:This makes sense.
Thanks.
Regards,
Graziano.
Glad to help.
Locking thread
