Hi all,
I have a clean basic install of RHEL 6 32bit (registered) and i'm getting a 404 during the fullinstall.
Here is my install.log output:
DISTRO INFO:
RedHatEnterpriseServer
6.2
i686
THIS IS A NEW INSTALL!
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
releasedate=2012-04-16
release=213
Configuring Yum...
package centos-release is not installed
rpmforge-release RPM installed OK
Enabling EPEL repo...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
169 169 169 169 0 0 189 0 --:--:-- --:--:-- --:--:-- 1920
error: open of <html> failed: No such file or directory
error: open of <head><title>404 failed: No such file or directory
error: open of Not failed: No such file or directory
error: open of Found</title></head> failed: No such file or directory
error: open of <body failed: No such file or directory
error: open of bgcolor=white> failed: No such file or directory
error: open of <center><h1>404 failed: No such file or directory
error: open of Found</h1></center> failed: No such file or directory
error: open of <hr><center>nginx/1.0.14</center> failed: No such file or directory
error: open of </body> failed: No such file or directory
error: open of </html> failed: No such file or directory
any help would be appreciated, thanks.
Installation Error, getting 404
Re: Installation Error, getting 404
Try running the following command from your installation directory. It will probably still fail, but it will help me understand what's going on.
Then post the output from that command.
sh -x 0-yumRe: Installation Error, getting 404
Heres the output:
sh -x 0-yum
+ . ./xi-sys.cfg
++ apachegroup=apache
++ apacheuser=apache
++ chownbin=/bin/chown
++ groupaddbin=/usr/sbin/groupadd
++ groupdelbin=/usr/sbin/groupdel
++ htpasswdbin=/usr/bin/htpasswd
++ httpdconfdir=/etc/httpd/conf.d
++ httpd=httpd
++ mkdirbin=/bin/mkdir
++ mrtgcfg=/etc/mrtg/mrtg.cfg
++ mysqld=mysqld
++ mysqlpass=nagiosxi
++ pgsqlrootpass=postgres
++ pgsqlpass=nagiosxi
++ nagioscmdgroup=nagcmd
++ nagiosgroup=nagios
++ nagiosuser=nagios
++ nagioswebpwd=nagiosadmin
++ nagioswebuser=nagiosadmin
++ phpconfd=/etc/php.d
++ php_extension_dir=/usr/lib/php/modules
++ phpini=/etc/php.ini
++ proddir=/usr/local/nagiosxi
++ useraddbin=/usr/sbin/useradd
++ usermodbin=/usr/sbin/usermod
++ userdelbin=/usr/sbin/userdel
++ xiver=2011r2.3
++ distro=RedHatEnterpriseServer
++ version=6.2
++ ver=6
++ architecture=i686
++ dist=el6
++ arch=i686
+ '[' -f installed.yum ']'
+ echo 'Configuring Yum...'
Configuring Yum...
+ case "$dist" in
+ '[' -x /usr/sbin/rhn_check ']'
+ /usr/sbin/rhn_check
+ '[' el6 = el6 ']'
+ rpm -q centos-release
+ rhn-channel -l
+ grep -q 'rhel-.*-server-optional-6'
+ '[' '' '!=' noupdate ']'
+ echo 'Updating system...'
Updating system...
+ yum -y update
Loaded plugins: product-id, rhnplugin, security, subscription-manager
Updating certificate-based repositories.
Setting up Update Process
No Packages marked for Update
+ '[' 'el6 i686' = 'el5 x86_64' ']'
+ rpm -q rpmforge-release
+ echo 'rpmforge-release RPM installed OK'
+ rpm -q epel-release
+ echo 'Enabling EPEL repo...'
++ curl -s http://fedoraproject.org/wiki/EPEL
++ grep -o 'http://\(download\|dl\).fedoraproject.org/pub/epel/6/i386/epel-release-[0-9.-]\+.noarch.rpm'
+ URL=http://download.fedoraproject.org/pub/e ... noarch.rpm
++ basename http://download.fedoraproject.org/pub/e ... noarch.rpm
+ PKG=epel-release-6-5.noarch.rpm
+ curl -L -O http://download.fedoraproject.org/pub/e ... noarch.rpm
100 14064 100 14064 0 0 21272 0 --:--:-- --:--:-- --:--:-- 2661k
+ rpm -Uvh epel-release-6-5.noarch.rpm
warning: epel-release-6-5.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 0608b895: NOKEY
Preparing... ########################################### [100%]
1:epel-release ########################################### [100%]
+ rm epel-release-6-5.noarch.rpm
+ unset URL PKG
+ yum check-update
epel/metalink | 12 kB 00:00
epel | 4.0 kB 00:00
epel/primary_db | 3.6 MB 00:00
+ echo 'epel-release RPM installed OK'
+ '[' el6 = el6 ']'
+ echo 'Yum configured OK'
Yum configured OK
+ touch installed.yum
sh -x 0-yum
+ . ./xi-sys.cfg
++ httpd=httpd
++ mysqld=mysqld
++ xiver=2011r2.3
++ version=6.2
++ ver=6
++ dist=el6
++ arch=i686
Configuring Yum...
+ case "$dist" in
+ '[' el6 = el6 ']'
+ rhn-channel -l
Updating system...
+ yum -y update
+ unset URL PKG
+ yum check-update
epel | 4.0 kB 00:00
+ '[' el6 = el6 ']'
Yum configured OK
Looks like some of the repo are getting shuffled around, we will have a new version out shortly that will resolve this.
Just downloaded it. Gonna give it a try over the weekend.
