SCHEDULE_SERVICEGROUP_HOST_DOWNTIME command not found
Nighthawkz
Post by Nighthawkz »
Hi all
I am currently running core Version 4.0.6 & am trying to regularly set a host group in downtime - hopefully as a cron job.
looking through the docs i came across SCHEDULE_SERVICEGROUP_HOST_DOWNTIME which seems to do what i want. except i can't make it do so:lol:
If i run this:
*/usr/local/nagios/var/rw/nagios/cmd SCHEDULE_SERVICEGROUP_HOST_DOWNTIME;Solaris dev servers;1110741500;1577666928;0;0;7200;test;test comment
from the shell either as root or user nagios i get "permission denied"
if i run it as a bash script (has permissions) as in the documentation here
https://assets.nagios.com/downloads/nag ... and_id=121
I get a "command not found" output
To me they're both the same thing just run in slightly different formats..but i get different error messages.
Am i missing something blindingly obvious here to get this working?
any help would be appreciated
regards
Re: SCHEDULE_SERVICEGROUP_HOST_DOWNTIME command not found
Nighthawkz wrote:To me they're both the same thing just run in slightly different formats..but i get different error messages.
These are not the same thing for sure.
What is the location of your nagios.cmd on your system?
Also, can you post the output of
which printf
Nighthawkz
thanks for responding
nagios.cmd is in /usr/local/nagios/var/rw
which prinft output:
/usr/bin/prinft
Nighthawkz
I originally posted the wrong command i was trying to use
SCHEDULE_HOSTGROUP_HOST_DOWNTIME is the one i'm looking to use
regards
mahtabalam
Post by mahtabalam »
Can you give me the contents of /etc/nagios/nagios.cfg
or /usr/local/nagios/nagios.cfg
Nighthawkz wrote:I originally posted the wrong command i was trying to use
regards
You should be able to follow the doc here but change /bin/printf to /usr/bin/prinft
https://assets.nagios.com/downloads/na ... and_id=123
Nighthawkz
@scottwilkerson:
thanks, i have read through and tried. When I try it, the log just gives this generic error:
[1570007290] EXTERNAL COMMAND: SCHEDULE_HOSTGROUP_HOST_DOWNTIME;Windows Servers;1569921625;1569943225;0;0;7200;lciav;Test Comment
[1570007290] Error: External command failed -> SCHEDULE_HOSTGROUP_HOST_DOWNTIME;Windows Servers;1569921625;1569943225;0;0;7200;lciav;Test Comment
[1570007290] External command error: Command failed
Nighthawkz
@mahtabalam
mahtabalam wrote:Can you give me the contents of /etc/nagios/nagios.cfg
i have attached it
thanks
config.txt
nag conf
(46.57 KiB) Downloaded 327 times
Nighthawkz
OK
I solved it
i was typing in the host groups name wrong :oops: apologies for wasting everyone time!
you can delete or mark this thread as solved!
thanks again!
Nighthawkz wrote:OK
I solved it
thanks again!
Great!
Locking
