"If problems persist... Send a notification every X minutes until the problem is resolved."
I nearly always set this to zero. However every Wizard insists on this being 60. I thought it was linked to the X_wizard_name template but it seems not, changing to zero there the wizard still comes up with 60 ? This is causing me some problems because in the "Unconfigured Passive Object Monitoring Wizard" step 5 this option is missing and is always set to 60 and I have a few hundred hosts to import so setting them all manually back to 0 is not an option. Sure I am missing something simple here to do with templates
However I probably wouldn't want to change this every type of Wizard template, and not change those that are already set ?
Nagios 2.3 Vmware image
