NRPE: Command 'check_mem' not defined
mahtabalam
I have installed NRPE in my server and created check_mem command in nrpe,cfg
The command is :
command[check_mem]=/usr/lib64/nagios/plugins/check_mem.sh -w 80 -c 90
Now when I create a active check in my nagios core which is
use vps-monitor ; Name of service template to use
host_name xxxxxxxx, xxxxxxxx
service_description RAM Memory
check_command check_nrpe!check_mem
it gives the output like below :
What should I do now?
The command is :
Re: NRPE: Command 'check_mem' not defined
Did you restart the nrpe service after modifying the nrpe.cfg?
If so can you show the output of
ps -ef|grep nrpe-
mahtabalam
scottwilkerson wrote:Did you restart the nrpe service after modifying the nrpe.cfg?
If so can you show the output ofCode: Select all
ps -ef|grep nrpe
- Screenshot from 2019-10-09 13-48-15.png (11.44 KiB) Viewed 14114 times
Ok, also show the output of
grep check_mem /etc/nagios/nrpe.cfgRe: NRPE: Command 'check_mem' not defined
Hi, I've similar issue. I wanted to monitor the memory of the remote server, I've placed the check_mem.sh on the remote server at /usr/lib/nagios/plugins. Added the command command[check_mem]=/usr/local/nagios/libexec/check_mem.sh 85 95 to nrpe.conf on the remote server. And when I test it from the Nagios server, i still get the command not defined error. The check_mem.sh has appropriate permissions, Nagios server has access to the remote server, I'm able to run other check such as check_load without any problem. What am I doing wrong?:
Did you restart nrpe after adding the command?vkodanam wrote:Hi, I've similar issue. I wanted to monitor the memory of the remote server, I've placed the check_mem.sh on the remote server at /usr/lib/nagios/plugins. Added the command command[check_mem]=/usr/local/nagios/libexec/check_mem.sh 85 95 to nrpe.conf on the remote server. And when I test it from the Nagios server, i still get the command not defined error. The check_mem.sh has appropriate permissions, Nagios server has access to the remote server, I'm able to run other check such as check_load without any problem. What am I doing wrong?:
Can you show the output of the following on the remote server?
ps -ef|grep nrpeRe: NRPE: Command 'check_mem' not defined
scottwilkerson wrote:Did you restart nrpe after adding the command?vkodanam wrote:Hi, I've similar issue. I wanted to monitor the memory of the remote server, I've placed the check_mem.sh on the remote server at /usr/lib/nagios/plugins. Added the command command[check_mem]=/usr/local/nagios/libexec/check_mem.sh 85 95 to nrpe.conf on the remote server. And when I test it from the Nagios server, i still get the command not defined error. The check_mem.sh has appropriate permissions, Nagios server has access to the remote server, I'm able to run other check such as check_load without any problem. What am I doing wrong?:
Can you show the output of the following on the remote server?What command are you using from the Nagios server?Code: Select all
ps -ef|grep nrpe
The output for ps -ef|grep nrpe:
ps -ef|grep nrpe
nagios 1548 1 0 Oct29 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -f
root 27449 25523 0 11:52 pts/0 00:00:00 grep --color=auto nrpeCode: Select all
grep check_mem /etc/nagios/nrpe.cfgCode: Select all
#command[check_mem]=/usr/lib/nagios/plugins/custom_check_mem -n $ARG1$Code: Select all
/usr/local/nagios/libexec/check_nrpe -H 192.168.xx.xx -c check_mem-
Several problems, you said you put the plugin at /usr/lib/nagios/plugins but your command path you set is /usr/local/nagios/libexec/check_mem.sh That would be incorrect.
Also, based on this, nrpe hasn't been restarted and has been running since Oct29
You need to restart nrpe for changes to take affect
nagios 1548 1 0 Oct29 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -fRe: NRPE: Command 'check_mem' not defined
Sorry, looks like I've given the wrong path for where I've had placed the check_mem.sh script. I've restarted the nrpe service a couple of times and its till showed Oct 29. I had to force kill and reboot the VM. Now, I get the error Unable to read the output.scottwilkerson wrote:Several problems, you said you put the plugin at /usr/lib/nagios/plugins but your command path you set is /usr/local/nagios/libexec/check_mem.sh That would be incorrect.
Also, based on this, nrpe hasn't been restarted and has been running since Oct29You need to restart nrpe for changes to take affectCode: Select all
Command on NRPE.cfg is command[check_mem]=/usr/local/nagios/libexec/check_mem.sh -w 85 -c 95
You have changed the path and the arguments in the different commands you have shown
if this is in /etc/nagios/nrpe.cfg
can you also show again the output of
Can you run that from the command line on the remote server?vkodanam wrote:Code: Select all
/usr/local/nagios/libexec/check_mem.sh -w 85 -c 95Code: Select all
ps -ef|grep nrpe
