Issue with send_nrdp
We are using nrdp version 0.3 and trying to do check on remote server, but getting below error
ERROR: The NRDP Server said NO TOKENS
Command on remote server
/usr/local/nagios/scripts/Syslog_duplication/send_nrdp.sh -u http://nagiosxiserver/nrdp/ -t pWiljdyhf -H syslogserver -s 'LIN_Server_Syslog_Monitoring' -S 2 -o "test"
Kindly advice ?
Kindly advice ?
Re: Issue with send_nrdp
For some reason the token doesn't appear to be configured in XI
Go to Admin -> Inbound Transfers
Click "Update Settings" to make sure the token is written to the configuration
If it still doesn't work, send the output of the following from the XI server
grep "authorized_tokens" /usr/local/nrdp/server/config.inc.phpRe: Issue with send_nrdp
I am still seeing the issue after click "Update Settings".
Please find requested output
[root@XXXXX ~]# grep "authorized_tokens" /usr/local/nrdp/server/config.inc.php
$cfg['authorized_tokens'] = array();
[root@XXXXX ~]#
[root@XXXXX ~]#
What are the permissions of this file
and the directories
What OS is your Nagios XI Server running?
ls -al /usr/local/nrdp/server/config.inc.phpCode: Select all
ls -ld /usr/local/nrdp/server/
ls -ld /usr/local/nrdpRe: Issue with send_nrdp
Please find requested details
[root@XXXX ~]# ls -al /usr/local/nrdp/server/config.inc.php
-rw-rw-r--. 1 nagios nagios 2744 Aug 28 15:10 /usr/local/nrdp/server/config.inc.php
[root@XXXX ~]#
[root@XXXX ~]# ls -ld /usr/local/nrdp/server/
drwxr-xr-x. 4 nagios nagios 76 Oct 7 13:39 /usr/local/nrdp/server/
lrwxrwxrwx. 1 root root 10 Aug 29 13:09 /usr/local/nrdp -> /drbd/nrdp
[root@XXXX ~]# cat /etc/redhat-release
CentOS Linux release 7.6.1810 (Core)
[root@XXXX ~]#
[root@XXXX ~]#
[root@XXXX ~]#
Weird, lets edit /usr/local/nrdp/server/config.inc.php
Change this
to this
Change this
$cfg['authorized_tokens'] = array();Code: Select all
$cfg['authorized_tokens'] = array('pWiljdyhf');Re: Issue with send_nrdp
I updated the config.ini.php with token.
Now I am getting the below error
[root@XXXX ~]# bash /usr/local/nagios/scripts/Syslog_duplication/send_nrdp.sh -u http://XXXX/nrdp/ -t hTRm7iP3kWrA -H XXXX -s 'LIN_Server_Syslog_Monitoring' -S 2 -o "test"
ERROR: The NRDP Server said BAD TOKEN
[root@XXXX ~]#
[root@XXXX ~]#
In your original post you were using pWiljdyhf as the token so that is what I had you edit the file to...bsivavani wrote: /usr/local/nagios/scripts/Syslog_duplication/send_nrdp.sh -u http://nagiosxiserver/nrdp/ -t pWiljdyhf -H syslogserver -s 'LIN_Server_Syslog_Monitoring' -S 2 -o "test"
now you are using hTRm7iP3kWrAbsivavani wrote:[root@XXXX ~]# bash /usr/local/nagios/scripts/Syslog_duplication/send_nrdp.sh -u http://XXXX/nrdp/ -t hTRm7iP3kWrA -H XXXX -s 'LIN_Server_Syslog_Monitoring' -S 2 -o "test"
You need to edit the file with the token you are going to use.
Used the same token in config.inc.php, but getting the error
[root@XXXX ~]# bash /usr/local/nagios/scripts/Syslog_duplication/send_nrdp.sh -u http://XXXX/nrdp/ -t hTRm7iP3kWrA -H remoteserver -s 'LIN_Server_Syslog_Monitoring' -S 2 -o "test"
ERROR: The NRDP Server said BAD CHECK RESULTS DIR
[root@XXXX ~]#
[root@XXXX ~]#
Now you have a different issue
Does that path exist? If so what are the permissions?
what is the path listed here?bsivavani wrote:ERROR: The NRDP Server said BAD CHECK RESULTS DIR
grep check_results_dir /usr/local/nrdp/server/config.inc.php
