email notification not sending all of a sudden
chewy
Post by chewy »
I have Nagios core 3.3.1 installed and email notifications had always been working right from the start with not special setup. Recently I noticed that emails are not being sent. I dont know what might have changed. I would like to eliminate the nagios box as the issue if possible. Could anyone lead me to what I can try to find out where the issue lies.
thanks!
Re: email notification not sending all of a sudden
Check your main config file first and see if you have:
enable_notifications=1
chewy
Post by chewy »
it is enabled
You can see if all of the filters are passed in order for the alerts to be sent:
http://nagios.sourceforge.net/docs/nagi ... tions.html
You can also check if sendmail is working fine. Create a test file somewhere and e-mail it to a good known e-mail address, for example, you can run in terminal:
/usr/lib/sendmail -v <your_e-mail> < /tmp/test.txt
You can also double check your spam folder :)
Hope this helps.
chewy
Post by chewy »
I must be missing something I go to send a test email and it said "mail delivery status report will be mailed to <root>.
lmiltchev wrote:You can see if all of the filters are passed in order for the alerts to be sent:
Hope this helps.
Check the root mail - it may help you troubleshoot the issue:
cat /var/spool/mail/root
