Fortinet FW and WAF
fsodah
Fortinet FW and WAF
Post by fsodah »
How to monitor Fortinet?
fsodah
Re: Fortinet FW and WAF
Post by fsodah »
The ports on the FW
Host is up (0.00022s latency).
Not shown: 997 filtered ports, 995 open|filtered ports
PORT     STATE  SERVICE
22/tcp   open   ssh
113/tcp  closed ident
443/tcp  open   https
161/udp  closed snmp
500/udp  closed isakmp
520/udp  closed route
2000/udp closed cisco-sccp
4500/udp closed nat-t-ike
MAC Address: xxxxxxxxxx (Fortinet)
mbellerue
Post by mbellerue »
Have you tried any of the plugins on the Nagios Exchange? It looks like we have a few related to Fortinet.
https://exchange.nagios.org/directory/P ... r/Fortinet
fsodah
Post by fsodah »
No results were returned from a scan of the device.
This could be due to one of the following reasons:
No results were found based on the settings provided
Could not connect to the host (10.1.xxxxxx) or the port (161) is unaccessible or blocked by a firewall
The snmp scan timed out (timeout currently set to 15 seconds)
The scan returned results, but did not return any results of the following filtered MIBs you selected (shown below)
SNMPv2-MIB
mbellerue
Post by mbellerue »
Okay, so it looks like you will have to open up TCP port 161 on your firewall, at least to the Nagios server.
fsodah
Post by fsodah »
I was able to sniff the SNMP by uploading the Fortinet mibs.... please close the ticket
benjaminsmith
Post by benjaminsmith »
Hi @fsodah,
Closing.
Thank you for using the Nagios Support Forum.
